Question about Kenmore Heating & Cooling
Our a/c is spraying water out of vents, what would cause this? It's a kenmore, 5000 BTU.
  • 6,927 Answers
The drain hole is stopped up,remove it from the window,and it`s shell,and clean it out with a water hose,be sure to remove all debris from inside the unit,and take notice around the drain,and the fan unit.Make sure there is a good tilt on the unit tilting out side,not in,so the water will go out the drain.If this was at all helpful,please rate,thank you.
Posted on Aug 02, 2010
I have a small 5000 btu window unit air conditioner made by arctic king does not have a hole for the excess water to drain.
I've repaired a lot of window units because someone has drilled a hole in the pan, to drain water, and hit the coil. Please do not drill any holes in anything! These units utilize condensate water to help reject the heat in the outdoor coil. If water is reaching the outdoor fan, it either does not have the proper "lean" or slope, or it's designed to allow water to reach the fan, and not much you can do. If it is designed to allow water to cool the outdoor coil, and you were to drain that water so that no condensate water cools the outdoor coil, this will allow the unit to operate with an excessive outdoor coil temp, and shorten the life of the compressor, or cause the unit to operate poorly/warm supply air temp. Try to give it just a little more "lean". Hope this helps!
Aug 18, 2017 | Heating & Cooling
Why does the air conditioner shut off and not start back up for extended periods of time
Does the fan keep running? If it does take it outside and clean the condenser coil and evap coil with a water hose. use a spray nozzle when doing this. See if this helps.
Aug 03, 2014 | Danby 5000 Btu Window Air Conditioner
How do I remove the vent adjustment to clean the inside out
a clothes hanger and a piece of cloth. also use bleach to kill the the remaining stuff so it doesnt come back.
Jun 19, 2014 | Sylvania Air Conditioner, 5000 BTU
Maytag 5000 btu air conditioner, model # m3x05f2a-c, is making gurgling sounds and spraying water, please help?
I could not find that model number listed, but no matter. It sounds like your drain line is plugged with something and you need to clear the line. What has always worked best for me is a guitar string because it is flexible enough not to damage anything but rigid enough to work on cloggs.
Jun 19, 2011 | Maytag Heating & Cooling
What is the power draw (in watts or amps) of the Kenmore 5300BTU room air conditioner? The unit is being powered off the grid by an inverter, and I think the user chose too light weight an inverter for the...
5.8 amps. see page 9 (5300 btu is considered a 6000 BTU, 4800 is considered 5000 btu, sorta like a 2x4 ain't really a 2x4 LOL)
You cannot run an ac on an inverter, not enough juice to get it started.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 28, 2010 | Kenmore Single Room Air Conditioner
Top rack does not wash dishes.
Possible causes of spray arm inefficiency:
Loading large or tall items in the lower basket which stops the arm revolving.
Upper spray arm split along seam.
Upper spray arm blocked.
Under dosing of powder causing foam and reducing upper spray arm water pressure.
Blocked strainers reducing water to circulating pump, therefore reducing upper spray arm water pressure.
inefficient wash motor impellor (faulty)
Dec 21, 2009 | Kenmore Dishwashers
Flashing code 90 .
The 90 error code is caused by two conditions:
1) the unit is under heating the water (not hitting the set temperature)
2) the fan is encountering resistance to air flow, which causes it to over correct
The most common causes for this conditions are:
1) insufficient BTU supplied to the unit
2) clogged fan motor or vent
3) insufficient makeup air
4) improperly installed exhaust vent
Nov 10, 2009 | Noritz Tankless Water Heaters N-0931M
Haier 5000 btu thru wall or window vents on top and both sides how far out the window should it be?
just a few inches, main thing is that its slightly tilted at the back to drain the condensated water outside
Jul 23, 2009 | Haier hwr10xc6 Air Conditioner
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Heating & Cooling Logo
183 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
