Question about Compaq Presario S4200NX (DF215AR#ABA) PC Desktop
PC is VERY sluggish...As a for instance, it took almost 20 seconds to bring up the control panel off the start menu...got the search flashlight. The 2nd time, the Control Panel popped right up. It seems like the problem is most prevalent after the CPU has been idle for a period(an hour?). It's not like we are doing a lot of gaming, just basic messaging & internet lookups. Any ideas as to what to do to make improve its performance.
  • 39 Answers
Go to http://www.yourwaresolutions.com/ and download the free version of FreeRam XP Pro, install, and use it. It sounds to me like you have something (either a program or utility) that is not releasing its' hold on your RAM.
Posted on Aug 02, 2010
How to Open the Control Panel?
Click the bottom-left Start button to open the Start Menu, type control panel in the search box and select Control Panel in the results. Way 2: Access Control Panel from the Quick Access Menu. Press Windows+X or right-tap the lower-left corner to open the Quick Access Menu, and then choose Control Panel in it
Oct 18, 2016 | Computers & Internet
Searching for a program by typing it in the start menu no longer brings up the program.
Use any system optimization utility and does a scan and repair. i recommed Advanced system care.
try to clear the start menu cache. if the problem still persist then go to
Control Panel\Programs and enable windows search. now restart the pc.
May 05, 2014 | Microsoft Computers & Internet
The control panel isn't working properly. How do
Try getting in through the start menu, your documents, and your search bar. If all fails, then start your computers command prompt, (type in search button in start menu: "cmd") just type in: "start control" and press enter; the control panel will launch. Also, if you type "run" in your start menu search bar and type in control followed by pressing the enter key, the control panel should start up.
Jun 22, 2013 | Computers & Internet
How can i unlock my keyboard
Recognize that you have a locked keyboard.
If your PC computer is not responding to keystrokes or is responding very slowly, you could have a locked keyboard.
Use your mouse to move the pointer over the "Start" button.
Use the left-click button to bring up the "Start" pop-up menu.
Position the pointer over "Settings" and use the left-click button to select. T
hen select "Control Panel." On some versions of PC operating systems, you can select "Control Panel" directly from the "Start" menu.
Select "Accessibility Options" to bring up another menu, then select "Keyboard."
You'll see three options that have check boxes.
Make sure each check box does not have a check mark in it.
The three options are "StickeyKeys," "FilterKeys" and "ToggleKeys."
Note that these options can become checked if the keyboard operator has repeatedly depressed the "Shift" key in rapid succession--or if the "Shift" key is held down for longer than eight seconds.
If the keyboard is still not responding, the problem could be that the computer has lost communication with the keyboard.
Turn off the computer.
Disconnect the power supply.
Remove and then reconnect the keyboard cable, then reconnect the power supply.
Turn the computer on.
This will reboot the computer, allowing it to recognize the keyboard.
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
How do you set up a login password if u deleted the control panel
For XP click on the start menu and then click on "Run" and type control panel and hit enter.
For Vista/Win 7 click on the start menu and in the search panel type control panel
That will bring the control panel up so you can access User Accounts to set up a password.
Regards.
Jul 01, 2010 | Acer Aspire 3690-2196 Notebook
Im losing channels on my tv. because i cant do a channel search
It's only thru your remote. try fixing your remote control.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Feb 23, 2010 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Pointer will not "tap"
This can be set to tap for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Tap to Click"
Check the box beside it and then click OK on this window and the mouse window.
Close the control panel by tapping the pad and you're on your way.
I hope this helps Fixya,
Chris
May 17, 2009 | HP TouchSmart tx2z
I have no sound. My audio controller,"this device cannot start.[code 10]"
Hi Empressandi. Have you recently updated your audio driver? If so try rolling back your driver. If your operating system is Windows XP goto start menu, control panel, system, device manager, locate your audio controller and click on roll back driver Likewise under Vista goto start menu, control panel and in the search box, top left, type device manager.
If this audio controller has never worked try searching for an updated driver.
Hope this helps.
May 01, 2009 | Dell OptiPlex 170L PC Desktop
How to turn off UAC
Start- Run/search- MSconfig- Tools Tab- Disable UAS- Click Launch- Restart the PC- Done
Feb 04, 2009 | Microsoft Windows Vista Home Premium with...
Can not get hd channels on my new tv..
First of all, digital/HD signals are broadcast at UHF frequencies. You need to know if you have an UHF antenna and, if you do, that it is pointed to the TV stations broadcasting HD.
Second, since most TV's have a setup mode that automatically searches for channels that are able to be received, go to that "Setup" menu on your TV and start the auto search. It will list both analog and digital stations. Note that the analog channel may be, for instance, Channel 39 but the digital channel will be Channel 39-1. Tune to the "dash 1" channel.
Dec 30, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Compaq Presario S4200NX (DF215AR#ABA) PC Desktop Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
