Question about 2wire 2700HG-B Router (2700HGB)
Se desconecta el modem cada 20 minuos+-
Se desconecta el modem del internet muy periodicamente y ya no se que hacer, porque he reportado a Telmex y no puden hacer nada.
el margen de ruido baja subitamente a menos -2.5 cuando se desconecta.
Necesito informacion . 2wire 2701
sandrew
  • 2961 Answers
SOURCE: 2 wire 2701 router
assuming all the settings (PPOA/PPOE etc) are correct and as long as you know you have got a broadband connection and it's not your service providers fault, check the you dont have a line fault then unplug the router for 30 seconds or so and try again.
Posted on Sep 09, 2007
SOURCE: Slow speeds compared to speedtouch 330 usb modem
How do you connect to the 2wire 2700HG? Wireless or ethernet? In any case I suggest to access the mdc (management and diagnostic console) of your 2wire and check the DSL Diagnostics under the Troubleshooting Category. Check the attenuation rate of your 2wire there so you can see if external problems are affecting the 2wire. The 2wire is also a modem\router and eventough it rarely affects the speed of your connection, the 2wire Firewall might also affect the speed of your cx. Another thing to check are the electrical interference on your 2wire. EMI (Electro Magnetic Interference) do affect the 2wire router greatly. I mean it LITERALLY. A great Interference can cut your signal strength from full bars to 1 bar even tough your just 10 feet away from the router. You can also check the Broadband Status on the Network at a Glance Page to check if the speed are jumping in and out. And also try to contact your Internet Service Provider or the 2wire direct technical support (1-877-3478680) for further assistance. God Bless!
Posted on Sep 17, 2007
JSPCEXPRESS
  • 178 Answers
SOURCE: 2wire 2700 not connecting to internet
Make sure you have DSL filters installed contact me if you need any help
Posted on Feb 11, 2008
shindou
  • 70 Answers
SOURCE: Having trouble staying connected to the internet
Thank you.
First, make sure that the wireless switch on your computer is on.
Then try following these steps:
1) Go to Start and click on Connect to.
2) Connect to a network window will appear. This window will show all available connections, which are dial-up, VPN and wireless connections, but your focus is on wireless connections. Scroll down the list and select the wireless network that you wish to connect, finally click the Connect button.
Note: If the network you choose is security-enabled network, means require authentication. One of the following will occur:
- If the network key is automatically provided by your network or system administrator (that is, the network supports IEEE 802.1x), the connection will be made automatically.
- If the network key is not automatically provided, type in the key. The key can be WEP/WPA/WPA2 encryption key.
Note: If you see the network is tagged as unnamed network, that is non-broadcast network with hidden SSID. When you make connection to this type of network, you will be prompted to type the wireless network name (SSID).
3) Once you connected to wireless network, the connection will show connected.
Then, you can go online. :)
Posted on May 01, 2008
SOURCE: connect wireless linksys to 2wire modem
put the modem on bridge mode and set the pppoe on the lynksis router and that should get you going
Posted on Aug 04, 2008
Prendo la pc acer y se apaga vuelve a prender y se apaga y asi sigue
Estimado Carlos,
Cuando la PC se apaga poco tiempo despues de terla prendido puede ser una senal de sobrecalentamiento del procesador. Si es una PC desktop, puedes verificar si el disipador de calor de aluminio y su ventilador estan colocados correctamente sobre el procesador y si el ventilador esta' funcionando. Si es una laptop, debes verificar si cuando la prendes el ventilador de las rejitas de ventilacion esta' suenando. Un ventilador que este' parado o con baja rotacion puede ser una de las causas del sobrecalentamiento. Pero, en los dos casos, si no es problema del ventilador del procesador, lo que hay que hacer es lo siguiente:
1 - Desarmar la computadora, y sacar el disipador de calor com mucho cuidado de sobre el procesador;
2 - Limpiar bien entre las ranuras del disipador de calor, sacandose todo el polvo y suciedad del mismo ya que el polvo ayuda a mantener el calor y sobrecalentar el procesador;
3 - Limpiar muy bien las rejillas de entrada/salida de aire, sacandose todo el polvo y suciedad,
4 - Rearmar el disipador sobre el procesador, pasando entre ellos una delgada camada de pasta termica plateada, que se puede comprar en tiendas de suminsitros y partes de computadoras (NOTA: no instale el disipador sobre el procesador sin pasar la pasta termica, porque podra' seguir sobrecalentandose);
5 - Rearmar la computadora.
Caso usted no tenga facilidad en armar y desarmar la computadora, seria bueno contactarse con un tecnico de su confianza para hacer ese trabajo para usted.
!Espero que esa respuesta pueda haberle sido util!
PD.: Como ese sitio web solamente accepta caracteres en Ingles, la acentuacion no puede ser utilizada normalmente...
Saludos,
Miguel Luiz Martins
Feb 27, 2014 | Acer Aspire Computers & Internet
Tengo el problema de que el carro ensiende pero despues de unos minutos como que se ahoga y se apaga y ya no quiere arranacar ademas de que no puedo regular la temperatura ventiladores funsionan la tem...
Hola, primero hay que arreglar lo mas urgente que es la temperatura, para esto lo primero basico es cambiar el termostato de temp del agua. Y sabremos si se apaga por lo caliente o porque.
Lo de los cambios tardios no deber de afectar el cambio de aceite asegura se la haya echado aceite de transmission adecuado hay un tipo para cada marca GM (dexron) y Ford TipoF (el Pontiac es GM) y revisa el nivel adecuado encendido el vehiculo y neutral
Dec 20, 2017 | 1999 Pontiac Grand Prix
Mi control de dish no quiere hacer nada quien me ayuda
Hola mi nombre es Kimberly Escobar con DISH Network servicio al cliente. Lamento escuchar que este teniendo un problema con su control de DISH Network, seria un placer asistirle proveyendole informacion que le sea de uso para resulusionar el problema. Si el control no esta haciendo nada primeramente debe asegurarse de que el control este en el modo de SAT significando que cualquier boton que oprima el control el boton de SAT en la parte de arriba se debe encender en rojo. Si ningun boton se enciende en rojo puede intentar poner baterias nuevas en su control, si no funciona significa que el control no sirve necesitaria uno nuevo, si el boton de SAT se prende en rojo puede intentar reprogramar el control a su recibidor. Para hacer esto tiene que accesar la pantalla de System Info en su televisor, puede hacer esto oprimiendo el boton de Sys Info enfrente del recibidor. Despues en el control va a oprimir el boton de SAT hasta que los demas se enciendan rojos cuando vea que se encienden rojos ingrese un numero entre 1-15 seguido por el signo de numero (#) y el boton de record una vez. Trate el control deberis funcionar. Tambien puede entrar a nuestra pagina web http://www.dishnetwork.com/SupportSection/remote-control aqui encuentra ayuda en como arreglar el control y el procedimiento. Si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH gracias espero esto le ayude.
Feb 09, 2011 | DISH Network IR Remote Control
Se activa y desactiva el compresor del aire acondicionado
Cuando pasa eso muy seguido digamos cada 10 segundos el refrigerante esta muy bajo, si esta en clima frio no use el defroster muy seguido el compressor se puede descomponer, va ha llegar un momento que el refrigerante este tan bajo que el sensor de presion no va a activar el compresor pero no se espere a que eso pase llevelo a reparar o ha recargar.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
Dec 19, 2010 | 1997 Toyota Tercel
Acaban de componer mi camioneta (pontiac montana sv6 1999) porque los buzos hidraulicos estaban pegados y no pasaban aceite (le pusieron nuevos), al siguiente dia de uso empezo a fallar la aguja del...
hola ayuda por favor. tengo una pontiac montana 97 y la falla es que en ocasiones da marcha pero no enciende a la primera. hace como que arranca pero se apaga. pero si acelero un poco al dar marcha si arranca y ya se mantiene normal. que sera. gracias. saludos
Nov 19, 2010 | 1999 Pontiac Montana
Por que mi carro honda civic 1994 se acelera y desacelera solo?
Cuando el motor sube y baja de revoluciones cuando esta andando pero el vehiculo sin moverse, puede ser que sea la valvula que se llama air control valve. En el honda civic esta localizada sobre el manifold de entrada, muy cerca del throttle body. La reconces porque tiene un toma electrico y dos mangueritas que conducen enfriador (antifreeze). Esta sostenida por dos tornillos. Desconecta el enchufle electrico y las dos mangeras y limpiala con limpiador de carburador en los puertos de gases de emision. Asegurate que en los tomas de las mangueritas hay pase sin resriccion. Espero que esto ayude y reporta tus resultados.
Oct 18, 2010 | 1991 Honda Accord
MI CADILLAC CATERA 98 PASA ACEITE A EL DEPOSITO DE ANTICONGELANTE Y EL CARRO CEMECALIENTA Y SE APAGA QUE DEBO DE ACE CAMBIA EL MOTO O Q
El problema está en el enfriador de aceite, que va instalado el el bloque del motor, justo en medio de las cabezas.
Cambiando el enfriador de aceite se resulve el problema. El # de parte es 93176626 y lo puedes comprar en www.rockauto.com el precio es de USD 235
Feb 18, 2010 | 1998 Cadillac Catera
Ibm 06p2525 alguien podra decirme como configurarla para que inicie desde el CD de instalaciã³n de XP pues en el bios, no viene opciones de arranque. Y ya probe con F1 hasta la F12 y ninguna me...
El disco de instalación y su programa que usa (¿windows XP home?) son muy diferentes y lo que usted quiere hacer no va a darlo ningún beneficio. Déjalo todo como se fué diseñado. Aunque si podría hacer esto el resulto estaría una computadora muy lenta porque se va a tener partes que mueven. En muy poco tiempo necesitarái un disco duro nuevo y un drive de CD-DVD. Tiene una mente muy inteligente, pero deja estas cosas en vivo. Déjame que te doy una precaución. No juega con la tarjete madre, porque es una cosa muy delicada, sino que no estás preocupado pagar cómo US $ 300- 500 dólares y labor de mano de igual, porque quemastes la targata madre. No tengo más tiempo explicarlo pero mantenga sus dedos fuera de esta cosa tan delicada. Muchas gracias para la consideración y opción de nuestro servicio. Mi nombre es Constantino )arzconst es mi contraseña interna con Fixya.com=
Jun 13, 2009 | Computers & Internet
2wire 2700HG-B Router (2700HGB) Logo
71 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
