Question about Miele W1926A Front Load Washer
Mold remain in rubber rim of washer
There are black mold on the rubber rim of the washer and very smelly odor when washer is in use. Can I replace the rubber rim to get rid of the odor.
    Scholar:
  • 91 Answers
Hi Qqiustin.There are couple of solution for this,you can try that before attempt to change door gasket.1- Run machine empty on Cotton 95C cycle,while it's intaking water add 300ml of bleach.(It could produce some foam but let it go & finish it's cycle)That progress will clean your machine & mould on the door gasket should get disappeared.Alternatively you can try EXIT MOULD or likely products on the super market sells.Follow the instruction.Goodluck.Thanks.
Posted on Aug 25, 2010
Hi , my frontload washing machine rubber rim has become mouldy. Can u suggest trhe best possible ways of cleaning it
The mold cannot be cleaned. The gasket has to be replaced to resolve the issue. To reduce the odor, you will need to purchase a washer machine cleaning solution at any hardware store.
Jun 15, 2011 | Washing Machines
Tip
Smelly washers
OK there are a lot of people with the smelly front load washer . the smell is caused buy a build up of detergent it is recommend that you use 2 tbs of detergent and 1 if you have a water softener. also leaving the door open after a washing is good to help it air out . to often people blame the door gasket because they get spots on them well the rubber used is a antimicrobial rubber so it cannot mold . the smell is actually soap build up trapped inside the washer if you run your washer with nothing in it and see soap suds your using to much detergent. there is hope though cutting back on detergent and using a product called Lemeshine mc3 will eliminate the odor issue.
on Jun 03, 2010 | Washing Machines
The rubber seal between the opening and the drum gathers dirt and stinks. Do I need to have this rubber seal replaced or just clean it after each wash with a damp cloth?
Here's what I recommend when asked:
Wipe the seal down liberally with a 50/50 bleach water solution. Pour the remainder into the tob, and add one cup of straight bleach. Fill the dispenser cups with bleach. Run the hottest, longest cycle with the hottest rinse cycle (for us, it is the "sanitary cycle"). After this cycle runs, run a normal cycle to flush out any remaining bleach residue. Here's the important part: leave the door open between loads. This allows the washer to dry out, preventing the formation of the mold, which causes the smelly odors. If you begin to see mold again, wipe it down with a disinfectant solution and continue to leave the door open.
Best regards, --W/D--
Jan 27, 2011 | Washing Machines
Something has to be done about this issue. Our Frigidaire washer is about two years old and the gasket is FILLED with mold. I have tried everything to clean it and now I am starting to worry about our...
Have a smelly HE front loading washer ?!
Need to get the mildew smell out of towels?
Have slimy black mold on the door gasket ?
Mystery smudges, spots or stains after washing
TechnoFresh™ is the Answer!
It's Guaranteed to Work!
or your money back...
Patent Pending
_______________________
Returning Nu Fresh Customers:
Nu Fresh is now called
TechnoFresh™
TechnoFresh™ is an even more effective formula
Nov 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Smelly washer
To compare washer cleaners go to: http://www.youtube.com/watch?v=Ua6OJPn0-fU
To remove mold odor from your washer, towels and clothing safely and easily use Smelly Washer Cleaner. It advantages over others:
24 treatments compared to 1-3 for competitors.
It's completely natural.
The only washer cleaner available that also removes odor from towels and clothing.
It's cheaper! Even ordered from our website it's less than $0.71 per use!
Jun 10, 2010 | Kenmore 24902 Top Load Washer
Stale odor within tub
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer emits a foul odor when washer first
You have the beginning of a detergent and/or softener residue buildup on the inside of the plastic outer drum of your clothes washing machine. Mold and bacteria need a moist, dark environment and a food source to grow. This residue is the food source. This can be a major health concern. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change the environment of the washer but we can lessen the "food source" by reducing detergent and fabric softener use.
Do an internet search on "Smelly Washer Reviews" to see what you can do about the problem of mold odor in your washer, towels and clothing.
After your washer odor is gone you'll need to change washing habits so mold and bacteria don't return. Go to the blog page at smellywasher.com to read the featured posts on the left side of the page on the cause of the problem and what to do for extreme cases of washer mold odor.
Dec 19, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Terrible odor from rubber seal around door. Don't know how to remove seal
Oct 14, 2009 | GE WSXH208A Front Load Washer
Mold Mold Mold
You are speaking the truth there , the really sad part is all brand front load washers will have mold/mildew build up due to the rubber boot seals they all use , the only way of fixing this is soaking and scrubbing with bleach which is not a fun job to do.
until they can figure out how to get all the water out after use we will have to deal with mildew.
top load washers use gravity to drain most water out so they dont have this problem.
Phil
Jun 11, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Build up of black "gook"
I also have had issues with a bad smelling LG Tromm 2277 washer when we leave the door closed after using it. One note on the LG site mentions that soap/scum buildup on the washer drum can encourage mold growth. They suggested running an empty wash load and then pause it after the water fills and add a hot tub cleaning product (Whirl Out - I got it at Lowe's) and restart the load. This stuff should help remove the soap scum and limit the smelly mold growth. My washer does not smell as bad after using it. I also have run an empty cycle with only bleach using the very hot sanitary load setting.
Aug 20, 2007 | LG WM-2277HW Front Load Washer
Miele W1926A Front Load Washer Logo
351 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
