Question about Dryers
I have an old kenmore electric dryer Model # 110.86872100 that wont start after i caught an article of clothing on the door switch (?)I am assuming thats what it is- as it is the prong in the front of the door. It is not loose now though--so I dont know what is the problem? I turned it on but then it stopped and when i opened the door thats what i found. I untangled the clothing and closed the door but it now will not start. I also checked the hot box for a flipped switch but it did not flip. PLEASE can you help me? There is NO way I can call a repariman. I fixed the washer dogs on my old Kenmore washer after research a few years back so im hoping I can do this as well! THANK YOU SO MUCH!
  • Dryers Master
  • 12,061 Answers
Http://appliancejunk.com/forums/index.php?topic=2931.0
At this link above you will find service manual for your unit. Simply use the troubleshooting steps and you should be able to sort it out.
http://www.acmehowto.com/howto/appliance/dryergoe.php
This link above will assist you with troubleshooting your unit.
I would assume your door switch, is faulty, again use the troubleshooting manual to isolate it.
Posted on Aug 02, 2010
Articles of cothing get caught between the rotating drum and the frame--I'm sure these are not the correct structural terms. Too often, when I open the door, something will be caught and hanging, and I...
Your drum seal between the drum and the body of the dryer needs replacement, this is what causes the clothes to stick and tear holes in them.
I hope this helps
Please rate me
Aug 10, 2010 | Frigidaire Electric Dryer
Clothes are getting caught and torn
yes. your drum gasket is bad
May 24, 2010 | Dryers
KENMORE lIGHT
I am assuming that your light bulb is good?
If so, your problem is your door switch.
Lighted dryers have 3 connectors on their door switch.
Sometimes when the switch fails either the light wont come on, or the dryer wont start. Either way this is a door switch problem.
Mar 05, 2010 | Dryers
Kenmore electric dryer stopped and wont start when button
Make sure there is 240vac then check the door switch, the start switch. Beyond the obviouse it is basic troubleshooting to work down to the failed component. Eric
Aug 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Dryer just stopped
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer series 90 model 66904691 will not start. Dryed a load of clothes went to start again will not do anything , checked fuse box, fuse not blown what could be the problem
Check the automatic door shut off switch and wiring. When the door closes it actuates a switch (completes and electrical circuit) which allows the dryer to operate.
Aug 23, 2008 | Kenmore Dryers
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
