Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Husqvarna chain saw Rancher fuel line replacement
    New Friend:
Ho do I replace fuel line on 460 rancher
Posted on Jun 15, 2013
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
steve_lima
  • 181 Answers
SOURCE: Pull cord on chain saw will not retract.
make sure the spring is going the right direction when pulld,put spring back in recoil housing carefully if you do it to quick it could spring back on you..... yes it hurts. after you have the spring back in the recoil housing take the rope off rope rotor.that's the piece that holds the rope.always replace to rope even if it looks good...feed new rope on rope rotor, first heat he ends of the rope so it will go in the holes easier.tie a hove hand knot in on end of rope.....put rope in rotor and pull knot thight,feed rope onto rotor until you have no more room for rope.... there should be a notch in rotor for rope to lay in....install rotor and screw tha hold rotor in place....have recoil handle handy....holding on to the rope spin the rotor two rotations....install handle......please be careful
Posted on Jan 09, 2009
dontbother10
  • 2220 Answers
SOURCE: Fuel Mixture Husqvarna 455 Rancher Chain Saw
Page 17 of your Operator's Manual says 50:1.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 25, 2009
dontbother10
  • 2220 Answers
SOURCE: What is Fuel Mixture Husqvarna 455 Rancher Chain
Duplicate post Close/delete
dontbother10
  • 2220 Answers
SOURCE: How do I replace chain on Husqvarna 455 rancher
Unlock the chain brake and remove the clutch cover. This should provide what you ask:
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you get stuck or need model specific instruction, there is very detailed illustrated instruction in your manual under "Fitting the bar and chain". The tool-less adjusters add needless layers of complexity IMO.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 06, 2010
High and low setting for hasqvanna 460
Husqvarna 460 Rancher Manuals
www.manualslib.com > Brands > Husqvarna Manuals > Chainsaw
Manuals and User Guides for Husqvarna 460 Rancher. We have 3 Husqvarna 460 Rancher manuals available for free PDF download: Operator's Manual ...
Jul 23, 2015 | Husqvarna 20" 60cc Rancher Chain Saw 460
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Aug 02, 2014 | Husqvarna "965030298 - 455 Rancher, 20""""...
Hard starting
Starting any chain saw can be a bit finicky. How many hours has the saw done since new ruffle? Over about 10 and the saw would have run in and will need to have the fuel adjusted. What fuel to oil ratio are you running?
Just as a point, you might know this but I only pull the saw over 3-4 times with the choke in. Then try to start with it off.
Feb 01, 2014 | Husqvarna Garden
What kind of oil do I need to use in my husqvarna 16" chain saw?
Unleaded fuel with Husqvarna two stoke oil mixed at 50-1, for the chain you need a non fling chain oil, both should be available from your local Husqvarna dealer.
Aug 21, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 rancher bogs down when i give it gas it's not even under a load new plug air filter, fuel filter, made carb adjustments like manual said running 93 octane gas.it,s still bogging
Make sure the chain break is releasing all the way. When the saw is not running release the chain break and make sure you can move the chain back and forth by hand. If you can there is a small fuel filter in the gas tank that should be replaced. Make sure the fuel lines are not spongy because they could collasp when the engine is running starving the carburetor for fuel.
Mar 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
What is the fuel mix ratio for a husqvarna 55 rancher chain saw ?
33:1.............always mix it on the heavy side and you will never burn your saw up.........go to walfart and get a bottle of "gumout" octane booster and stick it in the gas and it will run better than ever.......
Dec 17, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
329 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
