Question about Lexmark X2350 All-In-One InkJet Printer
Printer the printer scanner is stuck tried to use wd-40 but i can't get it to work
    Genius:
  • 3,587 Answers
Hooooooooooohhh...that's the last thing you want to use on a scanner...will really compromise the mechanism...the mechanism is quite exact in it's lubrication.
is that unit under warranty? that assembly is usually replaced in whole, not in parts.
Posted on Apr 25, 2008
Paper won't load. It gets stuck. Is there a way for me to repair? I love this calculator!
wd 40 is a lubricant.you want to clean the rollers with a cleaner.
try some isopropynol alcohol
Jan 21, 2015 | Texas Instruments TI-5640 Calculator
Tip
Be sure to replace glass to test! I wanted to see if the scanner would work...
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Apr 01, 2011 | Office Equipment & Supplies
Says paper jam but isn t one
It could be as simple as the rollers being dirty and its detecting a timing jam. or it could be that the exit sensor detection arm is stuck or sticking . if it was stuck you couldnt put another document in with out opening and closing the lid it would say jam. really sounds like its really dirty. now if it will run one with no problem its the seperation pad or roller depending on model. it tries to pull other sheet and it fails and shows jam but no paper in the unit . clean your rollers with wd-40 let sit few minutes 2 or 3 and retry. ya i said wd-40 you will be amazed.
Feb 17, 2014 | Canon Office Equipment & Supplies
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Paper jam out cassette
Odds are you are going to have to replace the paper pick up & paper feed and sep. rollers. You can also, try to clean the rollers with a rag with a very little bit of WD-40 and clean the three roller and dry off the WD-40 and see if that solves your problem. Good Luck
Jun 08, 2012 | Muratec Mfx-2500 Copier Scanner Fax...
Exhaust front pipe nuts rusted on
Try using a size 10 metric thin walled socket drive to fit nut with a little force. Use plenty of WD-40, soak the nut and stud. Try to turn nut for 1/8 turn forward, spray WD-40 then turn bolt back until it feels that it is stuck, turn nut 1/2 turn forward, spray WD-40 and try again to unbolt, everytime it feels it is stuck move nut forward, spray WD-40 then try again to unbolt. It is a slow process as it to prevent stripping the rusted nut and stud. Have fun.
Apr 15, 2010 | 2005 Gilera Runner VX 125
Access door to Photosmart 3210 is stuck open and won't close
I had the same problem. This is how I solved: I just spray WD-40 on the hinges and that's it, back in bussiness. Hope works for you too
Sep 16, 2009 | HP Photosmart 3210 Printer
Papers get stuck
Clean the feeder rollers with WD-40
Jun 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
Key stuck in ignition I forced it out now the car will not start
try a sqirt of wd 40 into the barrel and also down the shift lock mechanism
Dec 09, 2008 | 1998 Volvo V70
HP 3210 All in One Printer Lid
Carefully and I mean carefully spray some WD-40 into the elbows of the hinges. Carefully work the lid down and up until it is . Do not overspray into scanning area. Cover with a towel if necessary.
Sep 04, 2008 | HP Photosmart 3210 Printer
Lexmark X2350 All-In-One InkJet Printer Logo
16 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
