Question about Simplex Kaba Ilco Unican 1000 keyless lock
How do i change the combination of my M54 Simplex Cabinet. this is a hand gun safe.
2 Suggested Answers
SOURCE: how to change the combination of a Simplex pushbutton lock
Your screwed.
Posted on Mar 18, 2010
Bought this gun safe in 1998. Has a combination lock. Have the combination but it will not open safe.
If it is an electronic combination lock the batteries are probably discharged. In that case there should be a key and somewhere to put it in order to open the cabinet and replace the batteries. Electronic locks usually beep when the numbers are entered followed by a different beep if successful.
If it is beeping nice and loudly it would suggest you have the wrong code.
If it is a mechanical lock it must either be the wrong combination or the lock is broken and you will need specialist help, perhaps from the manufacturer.
Feb 08, 2016 | Locks & Locksmithing
Need factory code for sentry gun safe
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
Dec 21, 2012 | Sentry Fire Safe 24-gun Safe Combination...
Need to change lock code on a gun safe
In the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
"This is a lost combination situation.
Please call our Technical Service Dept.
For further information at (800) 849-8324
or (336) 725-1331."
They are located in North Carolina, so the best time to call is probably during east coast business hours.
Good luck--and please provide feedback if this helps!
Jun 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Hi, I have an older version of the Ilco unican corp pistol safe. IT is a simplex with the push buttons and a silver turner. I got it open, but don't know how to re program the code. Any help?
I found this instruction elsewhere on this site ( thanks to pctuneup191):
pctuneup191
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Good Luck!
Feb 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
My passcode is not opening my remington express gunsafe. I have tried holding the poles of a 9 volt battery to the metal area under the keypad but it does not work. What can I do at this point?
Gunsafes are meant to be difficult to open. I'm unsure as to your logic in the novel use of that 9v battery, all it would have done was to short circuit the battery.
Remington's own website gives you only one option if you're a US resident, "Contact Liberty Safes, the licensee, at 800-247-5625 for assistance with obtaining the combination to your safe.
If your safe is a low cost model and you need access quickly then you'll have to cut the safe open, but more expensive models are resistant to this form of attack and the safe will need to be scrapped and replaced afterwards.
Sep 27, 2010 | Locks & Locksmithing
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
437 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
