Question about Mtd 22" Yard Machine Push Mower
My helper was mowing with my Honda push mower.. The handle started shaking.. a lot.. It will start up at first pull but is not cutting well. The blade is turning but the mower is vibrating so much it bothers you hands to mow. The blade is not hitting anything and nothing in wound up around the blade.. What else could cause this problem
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
It sounds like the blade may have hit some thing hard .
You say the blade is turning is it turning level or is it sort of swaying as you may have ofset the drive pin.
Worst case.. new mower as it can cost a lot of money to repair drive
I know as i have done the same thing a few years ago
Posted on Aug 02, 2010
How to start it
      Stand behind the lawn mower. Use one hand to hold the engine stop lever in the operating position. Use the other hand to hold the recoil starter handle. Slowly pull the recoil starter handle until resistance is felt, then pull quickly to start the push mower engine.
      How to Start a Lawn Mower ' Starting Snapper Mowers FAQ
      www.snapper.com/us/en/support/.../how-do-i-start-my-snapper-lawn-mowe...
    Feedback
    How to start the lawnmower - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=QsRwZZwO4oc
    May 25, 2012 - Uploaded by iScaper1
    Tips on how to start a lawnmower. I asked my wife and boys today if they could start the lawnmower. One son ...
    How to Start a Push Lawn Mower: 7 Steps (with Pictures ...
    www.wikihow.com > ... > Lawn Care
    wikiHow... there's more to it than that, especially if you want it to keep running. Of course, how to start your individual lawn mower may vary according to what brand and...
Jan 12, 2016 | Garden
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
Mower goes to theleft while moweing & u have to push in more on the left handle to get it back in line,therefore cutting speed down
yes but you should of mentioned the brand/style/type of mower. adjusting the tracking isn't the same for every mower
Sep 11, 2014 | Garden
I cant pull the string to start the mower
pull plug out tie up bail handle see if you can turn engine over by hand if you can pull hard on rope it has jamed if not .move check for locked up mover add oil to cylinder for it to turn over till its free my have to take recoil off to do this if the reciol starter pawls or lock in
Aug 30, 2014 | Garden
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
My 22" MTD Yardman push mower runs too slow to cut much grass. How can I adjust it to run faster? It has no speed selection that I know of, only the handle bar that must be held tight to keep it running....
These inexpensive mowers are not made for large scale mowing. They're set to run as fast as they do and have low compression (read that as low power also) to make them easy to start and operate. About the only thing you can do to make it work better is keep the air cleaner clean, use fresh gas and keep the blade sharp so it cuts the grass easier. Mowing more often also means less cuttings under the deck so it works more efficently.
Aug 31, 2010 | Mtd 22" Yard Machine Push Mower
19.5hp 42" cut. Shakes when mower is engaged to cut
how hard does it shake? and does it mow?
most lawn tractor will shake a quick almost violent shake at first then it should vibrate quite a bit more while you are mowing this is just caused by the power being pulled from the motor to power not only the drive but the mowing deck. its normal.
if its worse than what i described you may have a bigger problem, if there is excessive clanking from the deck your blade may be loose/installed upside down.
Aug 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need a deck diagram for a 19.5 hp 42' cut
Craftsman 42 in deck makes terrible noise and middle wheel shakes. started while mowing.
Jul 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Bent Shaft???
Check that the blade securing bolt is secure. While you're there, have somone SLOWLY pull the starter rope. It will be obvious if anything is bent to the extent you describe.
If this machine has a blade clutch, engage blades while you do the pull test (DISCONNECT PLUG WIRE!!!!)
May 09, 2010 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
144 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
