NONE OF THE FANS ON MY SAMSUNG HLN5065W TV WORKS.
  • 10,594 Answers
Each fan has 3 pin connectors on digital board, check its voltage supply approx +10V on its connector, if volts are not present, follow the line that goes to power supply board and find out any fuse or some thing might blown and causing no volts to fans to run.
Thanks.
Posted on Aug 02, 2010
Samsung HLN5065W replaced the lamp. Tv wont stay on.
When your TV turns off without any reason, there are a number of possible causes. The problem could be a loose connection, a sleep timer that's been activated accidentally, or even a buildup of dust on the circuit board that causes overheating.
To help you better determine what the problem and solution might be, follow the simple troubleshooting steps in the article TV turns off. I hope this helps!
Aug 02, 2012 | Samsung HLN5065W 50" Rear Projection...
I have a 50 inch hLn5065w ,when i turn it on a very lous noise and vibration seem to be coming if your looking at the back of the tv its coming from the right side looking from the back.i know its not a...
Problem is the Color Wheel, Located behind the Lamp .
You will need a Flash Light and Pull Lamp out ,Look inside and you will see Color Wheel.
Color Wheel PN# BP96-00250A Price $82.66
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Feb 25, 2011 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
May 01, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
Nov 23, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W TV...picture freezes and will not
I solved this issue by junking it and buying a new one.
Oct 08, 2009 | Samsung HLN5065W 50" Rear Projection...
A Samsung Tv model #HLN5065W
Model # HLN5065W Digital Main Assembly Board should be part # BP94-00385A. Here's a link to a major Samsung distributor:
Samsung HLN5065W Replacement Part Digital Main Assembly Board
***There's also a manufaturer's notice: If you replace the digital main board (BP94-00385A) you must replace the main analog board (BP94-00434A) per mfg bulletin# ASC20040728004.***
Samsung HLN5065W Replacement Part Main Analog Board
Dec 30, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W, SVC#HLN5056WX/XAA - Made 12/2003
check the color wheel in front of the lamp
May 25, 2008 | LG 42LC7D-UB Television
Samsung tv
Replace the fan not turning, probably the lamp fan.
Dec 23, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
