Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Why is there ice on the back and bottom of my freezer
  • GE Master
  • 1,606 Answers
Refrig is NOT " Overcharged " . Just a simple test will confirm this .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Aug 04, 2010
  • Mike Smith
    Mike Smith Aug 04, 2010
    If this is solid ice under the freezer crisper and solid ( not frost ) ice a little ways up behind the freezer panel , then that suggests a clogged defrost drain . You would have to remove the freezer panel , thaw with a hairdryer , then use a small hose in the drain hole to blow out any debris . Hot water in the drain helps , IF , this is the problem you are refering to .
  • 37 Answers
Your system is over charge with refrigerant gas thats why its frosting inside and outside of your frige.....you must call a technician to decrease the charge of your system
Posted on Aug 02, 2010
The freezer is on the bottom of the fridge...and the bottom part of the freezer is forming a block of ice..just over 1 yr ago that i purchased the fridge. i tried moving things in the fridge forward so...
There is normally a "thing" that controls the auto defrost I had a freezer that started so it this out of the blue. Some how that "thing" got unplugged. It was in the freezer behind a panel in the back by the light.
May 28, 2017 | Maytag MBR2562HES Stainless Steel Bottom...
Freezer leak, Ice inside the freezer (AMADA ARB220ZC)
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 08, 2010 | Amana ARB220ZC Bottom Freezer Refrigerator
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
