We have a Panasonic TV model # CT-36SL13G. We have tried using the remote and manual button to turn it on with no success. House electrical circuts are all working fine so that's not the problem.Ca anyone help us?
  • 979 Answers
Hello Mahealanimar hi, This is a problem with most TV today, the power supply, Most flat TV today are power supply problematic and we get this problem everyday, if the TV is on warranty use it, the cost of repair is high,
Call your dealer and inform the incident. Get the best deal.
Servicing the power supply section needs disassembly and checking replacement of the power supply board, check also for open fuses. and bulging capacitors.
Posted on Aug 02, 2010
  • mahealanimar Aug 02, 2010
    Thank you Cyber for that information. Do you have a diagram of this particular Panasonic model? We would like to be familiar with all components so as not to shock ourselves.
Panasonic color tv remote model number EUR7613Z70 manual
You will usually find the instructions for using a remote control in the manual for the TV that the remote came with. For the Panasonic EUR7613Z70, this includes the CT-36E33. Panasonic has the manual on the CT-36E33 product page: http://shop.panasonic.com/support-only/CT-36E33.html . The direct link to the manual for the CT-36E33 is currenlty ftp://ftp.panasonic.com/television/om/ct-27e33_mul_om.pdf . The section on the remote starts at page 8.
I hope this helps.
May 16, 2018 | Panasonic Televison & Video
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
My Panasonic HDTV will not turn on
Mine did the same thing. Did you find out what to do?
Oct 11, 2009 | Panasonic CT-26WX15 26" TV
Panasonic ct-36SL13G worked fine, one day would not power up.
the plug fuse may not have blown but the fuse inside set may have blown, or dry solder joints on pcb
Jun 27, 2009 | Panasonic CT-32SL14 32" TV
How to unblock v chip in panasonic panasonic CT 27SL15 TV
Push the power button and the action button on the tv set until it shuts itself off and this will reset your tv. You cannot use the remote to reset...must use the actual tv buttons on the television set.
Jun 17, 2009 | Televison & Video
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Your using a universal remote from what U am understanding, Two solutions for ya
1)diffrent remote all togeather from radioshack
or
2) the Tv's IR is not working
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Panasonic CT-27SL14 27" TV
Panasonic ct-36sl13g
Mine did same thing. Found a fuse blown by the power cord inside case. Replaced it and power came back on.
Jan 13, 2008 | Panasonic Digital Video Duplex, Color...
Panasonic model CT-36SL13G TV
Your problem is most likely the thermistor , or degausser, is going bad. It is a little black box with pins and says D1R5M on it. It can be found by following the wire from the degaussing coil around the picture tube. The location number is CF803( i think)the Panasonic partnumber is D4DF1R50001. Also, I believe your fuse is 6.3A not 3.6A.
Nov 07, 2007 | Panasonic Digital Video Duplex, Color...
TV will not turn on
Should unplug the unit from the outlet first then after 5 minutes plug it back in,if this does not work it most likely needs service specially if you lost complete power in the house or if it was raining with lightning.
Sep 11, 2006 | Panasonic CT-32HL43 32" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
