Question about Samsung CLP 315 Laser Printer
Hello, I have a 32" Toshiba Regza TV, serial number: VX1A00081900/Model #HL67. This TV was great when we first got it but less than 2 1/2 years later, the picture is starting to go. It is almost like there is a "delayed" reaction as the picture moves (the images on screen move extremely slow and the color is very dark). We use a HD antenna to receive our signal and don not have any other issues with our other TV's. I was wondering if you have experienced this problem before and if so, what is the issue? I would like to repair it myself if possible. Thanks!
  • 2 more comments
  • stevernc Aug 02, 2010
  • stevernc Aug 03, 2010
  • stevernc Aug 04, 2010
  • Samsung Master
  • 11,800 Answers
Sorry, repairing by yourself without proper equipment is impossible. The only thing you can do is to replace entire boards.
Posted on Aug 12, 2010
  • Samsung Master
  • 11,800 Answers
The only thing that would cause something like that is when the image processor is malfunctioning - it's undervolted (something is wrong in th power source) , the processor is overheating or the processor itself is defective. The only thing you can do is to test the voltages, especially the 5Volts line to the processor. If you don't know how to do it then it's time for a pro, nothing more you can do.
Posted on Aug 04, 2010
  • 4,889 Answers
So you have audio lagging the video? In that case the first thing I would do will be to connect another input source to the tv to verify if the problem persists. In that way we will know if its indeed a problem with the tv.
  • eagle338
    eagle338 Aug 04, 2010
    Is it so hard to do what I have suggested? You have tried 5 different experts in one day. Way to go pal!
    Genius:
  • 1,112 Answers
Hello:
This could be a problem with the panel itself (Screen) try checking the auto backlighting to make sure the picture is at its brightest. Also it could be voltage error on the power supply itself, There are two capacitors on the power supply that may require replacing on this model they are use to power the Main system and digital control circuits, If you open the unit look at the power supply for buldging tops of capacitors there is usually two of them.
Posted on Aug 03, 2010
  • 10,594 Answers
I'm afraid, slow motion movement of picture in lcd tv is problem of lcd panel (screen), basically it is video signal processing/ slicing problem that occurs in circuit directly connected with lcd sheet to drive lcd pixels and it is irreparable.
Replace lcd panel to fix the problem but it would cost you approx 80% of new tv price. Replacement lcd panel will available in Toshiba service center.
This is not any operational or wrong setting issue nor it can be fixed with resetting or pushing any particular button. This is hardware problem that can only be solved by replacing lcd panel.
Thanks.
Posted on Aug 02, 2010
  • Samsung Master
  • 12,061 Answers
Www.tacp.toshiba.com/tacpassets-images/.../37hl67/.../37hl67_om_e.pdf
www.avsforum.com › ... › LCD Flat Panel Displays
http://www.service-manual.net/ashop/catalogue.php?cat=244&exp=0&resultpage=46&shop=1
Please look at these web sites above, they will assist you.
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of only a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace.
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
No picture, no sound, but TV will power up
Average life on all brands and models is 3 to 5 years. Average repair on this size and type of set varies but is usually from 150 to 250 parts and labor. I see very few sets of this type (any brand) that are more than 6 years old.
The bulk of sets in our shop (over a hundred sets on average) that have failed are under 2 years of age.
Dec 20, 2012 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Intermittent picture break up
What is your model number? Also when you say picture is breaking up do you mean the signal breaks up? Does it happen when you have the menu up also? Are you using cable or regular TV?
Feb 29, 2012 | Toshiba REGZA 32AV615 32 in. LCD TV
Hi i bought a new LED toshiba Regza 32 i see the Serial Number has been removed by hand ? is it risky ?
I should say so if you require a warranty repair as there is no serial number!
Jan 20, 2011 | Toshiba Televison & Video
Is my regza tv model 32rv635d hd ready or full hd.
Hello The Toshiba Regza 32RV635D is a Fully HD TV. with four HDMI connections.
Connections
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
http://www.techradar.com/reviews/audio-visual/televisions/plasma-and-lcd-tvs/toshiba-regza-32rv635db-679432/review
Hope this helps, if so do rate the solution.
Jan 03, 2011 | Toshiba REGZA 47HL167 TV
I've had my Toshiba 46RV530U less than 2 years,
Diana, did you ever find a solution? My Toshiba (same model) is about 2 years old and it started getting these 4 horizontal lines spaced pretty far apart and a double image at bottom. When I lightly tap the top of the TV, they went away. But now that is not working. Please let me know. Thanks.
Jeff
May 15, 2010 | Toshiba REGZA 46RV530U LCD TV
No picture, no sound. tv less than oone year old. toshiba 32" HD TV. Failed without warning
GO IN TOUCH WITH TOSHIBA AS THE SET WILL BE UNDER WARREN TIE ........SO FREE REPAIR AND SERVICE
Nov 19, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Oct 30, 2009 | Toshiba 52HL167 52 in. LCD HDTV
I have a 2 year old Toshiba 32
Your panel is defective.Not worth repair.Try calling Toshiba customer support and see if they will help you.
Sep 28, 2009 | Toshiba Televison & Video
Two DVD's stuck in Toshiba Regza with built-in DVD player
If you can find a piece of stiff wire, put a small 90 degree bend onto one end and try to hook the edge or middle of the DVD drawer and pull out the drawer. It will resist a bit but should come out.
Jun 01, 2009 | Toshiba REGZA 47HL167 TV
Samsung CLP 315 Laser Printer Logo
110 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
