Question about Compaq Armada E500 Notebook
E500 im trying to install win xp-sp2 on armada E500 it halts during setup on the copying driver.cab and it would not finish its just stop , the cd is not original becouse it did breakdown so i took another cd and tried to install the win xp but i have this proplem dose any one have a soultion,,,,,,,,,,,,,,,thanks
  • 54 Answers
First tell that which O/S it had earlier coz armada e500 notebook comes with 64 MB RAM and 12 GB HARD DISK , had you upgraded your notebook with RAM AND HARD DISK .
If not then check the hard disk space you have left in the notebook
Posted on Apr 25, 2008
I have upgraded my compaq armada e500, it has all the requirements to upgrade from windows 98 to windows xp. i tried to install a fresh copy of xp, the set up stops in the middle. i tried several times...
We check of the requirements of you loptop to isntall a windows Xp so we determine that windows xp you installed is not a genuine..
maybe the OS that you installed is not a genuine so you cannot install .it.try to install a genuine OS
Aug 31, 2011 | Compaq Armada E500 Notebook
Good night, i formated the hdd of my compaq armada 1500c, next i install win xp sp2, every time that the computer boot, i see a mesage that says system date and time not set. how can i restore the bios...
There is not a bios partition, as the bios is a firmware on the mother board. You need to press the key specified early during boot up, before the system seeks the hd for load.
Oct 02, 2010 | Compaq Armada 1500C Notebook
Xp recovery
You need to download all the drivers installer files from manufacturer website first, and also all the software you want to install automatically with Windows. Then you build a Windows Xp boot CD with all the software setup embedded.
See the links below:
Build an XP-SP2 Recovery Disc - Solutions by PC Magazine
Geek Repair: Create Your Own Ultimate Recovery CD :
Bart's way to create bootable CD-Roms
Slipstream a Windows XP SP2 Recovery CD
Build your own XP SP3 Recovery Disk -
Build an XP SP3 Recovery Disc
Apr 18, 2009 | Microsoft Computers & Internet
Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Mar 25, 2009 | Toshiba Satellite 5105-S501 Notebook
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Aug 20, 2008 | HP Compaq Motherboard
Notebook won't book from CD
could you start setup from windows? if you can, do that. but the not booting from CD problem, it might just be the cd cause that's happened to me where certain cd's won't boot.
May 04, 2008 | Compaq Armada E500 Notebook
Install xp-sp2 on compaq e500
If not then check the hard disk space you have left in the notebook.
Apr 25, 2008 | Compaq Armada E500 Notebook
Win xp pro setup
if you have the original xp disk with a cd key , then its perfectly legal for you to download a iso copy of xp , and install it, if not try and make a copy of the disk , and use that , or someone u know may have a friend with a xp disk , thats fine also aslong s you use the key that comes with your disk
Nov 26, 2007 | Microsoft Windows XP Professional for PC
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Boot sequence problem
try booting to DOS screen only by inserting a boot-able floppy disc (I use Win ME disc at this point although my system is also Win XP). Then select "boot with CD-ROM driver". It will detect your CDROM drive and assign a letter. Now insert the CD and boot from there. I have done this sequence many times with no problems.
Jul 13, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
169 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
