Question about Akai Televison & Video
My projection tv has distorted picture
My projection tv had a burnt plastic smell . Picture is distored color is bad. A friend who looked at it and he had a projection tv said it might be a convergence problem. The Tv is 6 and a half years old. Is it worth fixing ?
Thank you,
  • Joy Gerard Aug 02, 2010
    The solution is helpful I will call a repair person tommorow. Thank you,
  • 10,594 Answers
It might be convergence problem and/or some thing like high voltage block that plastic cover is burning.
What is model number of your Akai tv to determine possible cause of problem.
Thanks.
Posted on Aug 02, 2010
    The model # is PT4299HD,
  • Shahid Electronics
    Shahid Electronics Aug 02, 2010
    Yes, visual check is necessary inside tv after taking off its back cover to see what part is getting heated and causing plastic burn smell. Local tv repair shop will help you to get tv fixed.
    Since tv is more than 6 years old so ask an estimate of repair to decide about its repair.
    Thanks.
Why is my picture color distored color?????????
Your color is distorted because your color wheel is probably going bad. Try resetting all the picture values first. Sometimes they need to go back to normal when the lamp is changed. Lamps only provide white light and have no bearing on colors unless they are very dim. Also check your cables. a loose or bad cable can cause this as well. Lastly make sure your new lamp is made by Osram or Philips. knock offs wont work.
Feb 21, 2015 | Mitsubishi WD Televison & Video
I have a 60" rear projection tv and the picture looks like its missing a color the picture isnt distorted or anything but the colors are bad what could be the cause and the fix
sounds like a Phillips or magnavox that has bad CRT coolant which needs replacement. If so you can get the Phillips CRT coolant repair kit from www.tvrepairworld.com it comes with instructions and the coolant for all three CRts,
Mar 01, 2013 | Televison & Video
My tv when it turns on there is no color and after a while the colors appears, also the picture is distorded, any sugestions?
Its a older set and I have fixed and even owned one---bad solder connections and or convergence problems---can you describe better what it looks like when cold?
Nov 04, 2012 | Televison & Video
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Distored picture
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Sony KP-46WT500 46" Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I was watching TV this morning, and I heard a slight pop from the back of the TV the picture then became distorted, blury, and off color. There is also a "burnt" smell coming from the rear of the tv, I...
One of your capacitors n the video board burnt out. You will have to use a multi-tester or capacitor tester with service manual to determine which capacitor it was that burnt out.
Jul 06, 2009 | Akai PT4799HD Rear Projection Television
Distorted picture. changes from color to black and white.
Hi, this is a bad main board that is causing this issue you are experiencing. simply replacing this board will fix this issue.
Click Here
May 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TV Picture Distorted
You need new convergence ICs Call your locally tv repair shop or find someone that knows how to work on CRT projection tvs.
Aug 29, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pictue problem
One of your convergence output IC's has burnt out and needs to be replaced. When the IC that handles the Red Vertical (RV) channel goes bad then a small low-value resistor usually burns out with it and the red color will sag inwards at the top and bottom. If you have no experience in repairing and realigning convergence circuits then allow a qualified tech to handle it for you.
Jul 07, 2007 | Toshiba 50H72 50" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
