Question about Dell Latitude D800 Notebook
My latitude won't find a wireless connection. Always says that the cable is unplugged. How can I fix this? I just want to be able to connect using wifi and not DSL or a modem. Thanks.
  • 734 Answers
HI There,
To try to help you, I'll have to make some guesses.
Guess#1. You're using XP and the message says "A Network Cable has been/is unplugged". That means you should see 2 small icons at the bottom right corner of your screen that look like one little computer monitor in front of another, Both should have a red X on them.
If there's only one icon with a red x then it means that your laptop has not recognized its interior wireless card or may not even have one at all. Most Dells of that era have a keyboard combination to activate your wireless card. You would hold down the "fn" key and while doing so, go up to the top of the keyboard and press the F2 once,
After that, you should see 2 icons at the bottom right with red x's and one should have a bubble message saying "Wireless Networks are available, click here to connect"
If that doesn't happen, 1, You don't have a wireless card installed inside the computer or 2., You should seek out some assistance from someone nearby who knows how to go and check the several other possibilities for you. The other possible solutions are a bit advanced and sometimes overlap so it would be tough to advise you thoroughly here.
Best Wishes
Posted on Aug 02, 2010
    Scholar:
  • 72 Answers
There will always be a cable unplugged if you are using a wireless internet connection, that will refer to your hard wire connection.
First, you want to make sure there is a wireless access point nearby (i.e., a router in your home, or a WiFi hotspot). If you don't have one of those nearby, your computer cannot magically connect to the Internet. You can right click the wireless icon in the lower right-hand corner of your screen, and click "View Available Wireless Networks." This is assuming you are letting Windows manage your wireless connection, otherwise it should be something similar. If you do not see any wireless networks after refreshing, make sure the wireless on your notebook is turned on, and not disabled by a switch or button. Finally, if you still don't see any wireless connections, test to see if any wireless networks are available with another notebook if available, to rule out any problem with the notebook itself.
My 2WIRE router won't give out wireless signal.
Unplug the ISP modem and the 2wire, Check ALL cables and reseat connections, plug in the ISP modem, wait for selftest, plug in wireless, wait for selftest, does your wireless SSID show in Available Wireless Networks on the Laptop? Can you connect using a Ethernet cable to verify it's getting a signal? Contact your ISP and have them verify the signal, have a ISP tech come out to analize the signal, it may be outside?
Feb 07, 2013 | 2wire Computers & Internet
Why does my latitude d810 say there are no wireless networks available?
Have you rebooted your machine? shut down, unplug from AC remove battery, plug in, reboot. Try to connect. Is the wireless adapter enabled? Have you tried a Ethernet cable? Have you rebooted the wireless device?
Dec 17, 2012 | Dell Latitude D810 PC Notebook
Dell Latitude E6410 does not connect to wireless printer
connect it by cable to your pc first to install it then remove the cable
Feb 11, 2012 | Dell Latitude E6410 Laptop
I have a Latitude E6400. I have tried to use the wireless connection but it wouldn't connect. I have to connect to the internet via an ethrenet cable only. It restricts my movement & makes me handicap.
make sure the wireless switch is on then try to update the wireless driver of your computer. you can download the latest wireless driver from your computer manufacturer's web site then restart the computer
Jun 11, 2010 | Dell Latitude E6400 Notebook
Local area connection cable unplugged message when brand new network cable is plugged in.
you need to remake the connection and check if is static ip or dinamic(DHCP),and if you cannot connect the check if is instaled the proper driver for your network card.
Nov 25, 2009 | Dell Latitude D610 Laptop Computer -...
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have to turn the modem off and back on every time i get on my computer to get it to connect to my dlink router. how can i solve this
If it is wired through the LAN ethernet connection directly to your computer it is cause by unplugging the ethernet. Routers and modems hate a ethernet cable unplugged and will stop communicating if unplugged. You will have to reset almost every time. When reset the router goes out and looks at what is connected and then handshakes with it. If it is a wireless issue you can reset your wireless setting in your control panel. This shouldnt happen as your wireless network should always be broadcasting. Generally, to connect back to a router you only need to unplug the router to re-establish the connection to the modem. Going all wireless is the only way to fix this
Oct 11, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Intermitant signal
on your computer goto start - run - type services.msc and press enter.goto wireless zero configuration and enable it. now goto start - run type msconfig and press enter then goto startup and uncheck your netgear adapter.press apply and OK or close. restart your computer.goto start - control panel - network connection then right click wireless network connection and view available wireless networks.select your network and connect.once it`s connected goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it. now right click wireless network connection again and click on properties and double click on internet protocol(TCP/IP).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
this will fix your problem...
Jun 11, 2009 | Arris SURFboard SBG900 Wireless Router...
D610 won't acquire network address on wireless connect.
check firewall also check driver do you have a password on wireless router for wireless card
Mar 28, 2009 | Dell Latitude D610 Laptop Computer -...
Cant get on internet via wireless or wired connection.
use the lan connection to get online, then once prob clears you should be all set, otherwise back up your data and a fresh install always does the trick
Nov 20, 2008 | Dell Latitude C400 Notebook
Dell Latitude D800 Notebook Logo
305 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
