Question about Samsung WF337AA Front Load Washer
I have a samsung i did a load of washing this morning with no problems when i put the second lot in it started beeping and is displaying 4e i cant find my book so i don't know what the problem is
  • 15,935 Answers
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I have a samsung front loading washer and I am getting error code 4E and cant find book help
Water supply problem causing a 'time-out'.
The 4E (4C) error is displayed on the panel of my washing machine ...
www.samsung.com/.../the-4e-error-is-displayed-on-the-panel-of-my-washing-machin...
  1. Cached
4E (4C) ERROR. The 4E (4C) error indicates that the washing machine has detected that there is a problem with the water supply. The most common reason for this error is a blocked or kinked water supply hose.
There are videos here
samsung front load washer error codes 4e Google Search
Apr 05, 2018 | Samsung Washing Machines
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
4e on my samsung front load WF42H5000AW
A 4E code indicates your machine is not sensing that it is filling. The corrective action is to check that water supply is on and has adequate pressure, hoses are not kinked, and that filters on the inside end of the water valve are not clogged.
Nov 21, 2016 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What does nf code for a Samsung front load washer mean?
    Water Inlet problem.
    The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
    To troubleshoot this error further, follow these steps:
    Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
    Step 1: Turn the machine OFF.
    Step 2: Turn the water tap OFF.
    Step 3: Remove the water hose from the tap and dispense the water into a sink.
    Step 4: Remove the entire hose.
    a. Check for Kinks.
    b. Check for Clogs.
    Step 5: Check if water supply is good.
    Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
    Step 7: Check and clean the second mesh filter.
    Step 8: Test the unit by turning it on and by performing a normal wash cycle.
    Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
    Washing machine displays 4E or NF Error Code
    Dec 02, 2015 | Samsung Washing Machines
    I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
    Aug 08, 2010 | Samsung WF203ANW Front Load Washer
    4E showing on Samsung Washing Machine
    Apr 06, 2009 | Samsung WF337AAL Front Load Washer
    Samsung front loading washer temperature sensor problem
    It may not be your temperature sensor or thermistor. If you have a tE error code on your Samsung washing machine, first check the wiring. My Samsung washer had three visits by the repair tech. and new parts ordered again and again. I looked on a British web site and two people said that it turned out to be wiring broken in several places. Sure enough, I found a broken wire. Technician didn't look for that. Hope it's as easy for you.
    Feb 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    4e code
    I just checked the Samsung website - you can download the manuals if you've lost them (website below). Not sure what washing machine you have but a 4E on model J1043 (which is the machine I have) says to check the following:
    i_1.gif Make sure the source water faucet is turned on.
    i_1.gif Check the water pressure.
    http://downloadcenter.samsung.com/content/EM/200701/20070109165927703/EN/J1043-01986D_sub7_eng_050708.htm
    Hope this helps.
    Dec 26, 2008 | Samsung WF337AA Front Load Washer
    Samsung Washing machine fault
    The manual says Mke sure the soucre water faucet it turned on. Check the water pressure. turn off water and unscrew the hose from the back of the washing machine. it says to pull out the nesh filter from the end of the hose and ricse it under water until clean with a pair of pliers.also clean the inside and outside of the threaded connector. push the filter back into place, screw the hose back onto the washing maching. turn on the faucet and maike sure the connections are watertight.
    May 15, 2008 | Samsung WF203ANW Front Load Washer
    Samsung WF337AA Front Load Washer Logo
    161 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
