Question about Sharp AL-1641CS Laser Digital Copier
"P" is blinking in display Sharp AL-1641cs
"P" is blinking in the display and there is paper in paper tray and no paper is jammed anywhere in machine. Makes strange sounds from right side of machine.
    President:
  • 2,072 Answers
There is a small white gear that drives the fuser module. It wears out at 30 to 40 thousand pages.
If the sound is a jumping to gringing noise that would be the problem.
That gear jumping will cause the machine to say out of paper,, jam,, give all kinds of problems from things bouncing around.
Posted on Aug 02, 2010
I have a Sharp AL-1631 Copier. The 'P' Light comes on indicating a paper jam, however when I open the machine there is no paper jammed. Any suggestions?
Check the dash and see if the lower tray is selected or the by-pass tray on the side. If the side tray is selected change to the bottom tray.
May 13, 2011 | Sharp AL 1631 Copier
Tip
Sharp AL-1641CS Copier Manual Download
Free Sharp AL-1641CS Copier Manual Download
Models: Sharp AL-1632 / Sharp AL-1641CS
Would you like to review the features of the Sharp AL-1641CS Copier?
Have you lost your Sharp AL-1641CS Copier Owner's Guide?
Would you like a free digital, searchable, pdf version of the Sharp AL-1641CS Copier Manual?
Follow this link
(& click FREE) to download a pdf version of the Sharp AL-1641CS Copier documentation.
I hope that helps.
___________________________________________________
on Jul 24, 2010 | Sharp AL-1641CS Laser Digital Copier
I had a paper jam.I cleared the jam. the misfed light is still blinking. doese this model have areset botton?
There is no reset button or switch. The reset is performed by opening and closing the right side door. Make sure there is not a sheet of paper just starting out of the tray. Also check the fuser gate. Sometimes these break. The rear side of the gate has a small tab that blocks a sensor. If the gate is out of position it will show a jam all the time. Just make sure the rear side tab is "in" the sensor housing. The gate looks like this:
afa6551.jpg In this picture the "sensor" tab is at the far end of the picture.
Good Luck and Thank You for using Fixya.
Jun 09, 2010 | Sharp AL-1641CS All-In-One Laser Printer
"P" is blinking. There is no paper jam. Paper is not feeding from the paper tray.
Hello sir; there is paper pick up roller dirty or worm, need to clean or replace.
Apr 28, 2009 | Sharp AL-1451 Laser Printer
Paper misfeed indicator light continues to blink even after paper
some machines will want all covers to be opened, then closed, for good reset. if you are having jams in the adf, then open all adf covers, and lift the adf upward, if it allows. also, try turning unit off, then back on. some jams only clear that way.
Apr 02, 2009 | Sharp AL-1641CS Laser Digital Copier
Copier flashing P when after trying to copy
Make sure that the tray has paper in it and that the copier is using that tray(there should be a light for the tray selected) . If it is set to use the manual bypass tray and there is no paper it will give "P" in display.use tray select button to select tray with paper in it.If trays have paper and still gives "P" try to clean feed rollers ..
Mar 09, 2009 | Sharp AL-1641CS Laser Digital Copier
No Copies
It could possibly be your main charge assembly. If there is no charge on your drum, it can lead to blank copies.
May 20, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Sharp AL-1641CS printer/copier
Most likely you had a toner cartridge failuer leaving some of the ink and developer in the crevices above the paper feeder and its just trickling onto the paper.
It pretty much needs to have the cartrides taken out and thouroghly vaccumed.
Just takes patience and time to get it all removed.
Dont vacuum the cartridges, but the inside of the machine.
Pull your paper tray out and see if there is toner and developer trickling into it.
Jan 09, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Sharp AL-800 copier
If you check in the unit where the paper first leaves the paper tray, there is a small black lever called a sensor flag that should move freely in and out of a sensor led.Also one or two more inside the machine and where the paper exits the unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 06, 2007 | Sharp AL 800 Copier
Sharp AL-1641CS Laser Digital Copier Logo
287 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
