Question about Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S
It turns on ,starts to get warm.Then turns off
    Scholar:
  • 73 Answers
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Posted on Aug 04, 2010
My hot water won't heat up the flame come on but the water is luke warm to cold
Hmmm. Those btu's have to be going somewhere.
Is the flame turning off too soon? A gradual problem or did the unit suddenly start acting up? Sounds like a thermostat issue and not a particularly difficult job with YouTube guidance.
Apr 13, 2017 | Water Water Heaters
When i turn on the shower the water will be warm for one minute and then cold, I have to turn it down and open again to get warm water
Reasons for this: ???
  • bad elements,
    • if one is bad, just replace both
  • bad thermostat or both of them?
  • broken dip tube / cold water mix tube
    • Notice the "RED" in the 1st pic on the left. 90% + of the tank is hot, with a broken tube, 75% of the tank is luke warm to cold.
Check for them. not that difficult of a fix
Mar 13, 2015 | Water Water Heaters
The flame in my noritz tankless water heater turns off when I lower the pressure of water flowing from the faucet (however when the flow of water was at high pressure the flame never turned off). This also...
has this heater always acted like this? if so
you need to supply heater with the right water pressure or flow
try cutting back by turning inlet valve off to restrict flow or restrict flow on hot end. hope it works it did on mine
Dec 30, 2014 | Water Heaters
No hot water comes into the house
1) Copy following link:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#no
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
2) One pipe on top of heater is warm??? >> breaker is ON >>> this indicates that electric water heater has hot water.
When you opened the TP valve, did hot water come out???
3) Feb 2013 >> add a comment.
Feb 24, 2013 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
MY WATER HEATER NO WORK.................THE PILOT WORK WELL BUT WHEN I TURN TO START WARM THE WATER WORK FOR 5 SECONDS AND TURN OFF??
1) FV lockout.
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
2) Air intake screen is clogged, and this caused overheating, which tripped FV system.
2) Add a comment with brand water heater and approximate age of heater for more help.
3) Contact manufacturer.
Read product manual.
Feb 04, 2013 | Water Heaters
Tempra 36 luke warm
turn thermostat up, if that doesnt do it, replace therm.
Dec 20, 2012 | STIEBEL ELTRON TEMPRA 36 Tankless Water...
Hot water from the tank is only warm, Temp on the tank is at Hot
does the flame stay on all the time? sounds like bad gas valve/thermostat
Feb 24, 2012 | Water Heaters
My jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
Apr 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
WE HAVE CHANGED THE THERMOSTATS BOTH OF THEM, WE HAVE CHANGED BOTH ELEMENTS AND THE WATER STILL DOENT GET HOT ENOUGH. WE HAVE TURNED UP BOTH THERMOSTATS AND STILL NOT HOT ENOUGH. WHEN YOUR RUNNING THE HOT...
WE THOUGHT WE NEEDED ANOTHER THERMOSTAR, BUT WHEN WE WERE LOOKING FOR THE PART THE EMPLOYEE ASKED WHAT WAS THE TROUBLE. WE EXPLAINED, HE SAID YOU DEFINATLY DO NOT HAVE A PROBLEM WITH YOUR TANK AND ASKED IF WE HAD A SINGLE HANDLED FAUCET WITHIN THE HOUSE. NO WE DONT. HE SAID IT SOUNDS LIKE WATER IS MIXING WITH THE COLD WATER THATS THE REASON FOR THE WARM--COLD--WARM WATER. COME TO FIND OUT SINCE WE ARE REMODLING THE BATHROOM, WE HAD BOTH THE HOT AND COLD WATER TURNED ON IN THE SHOWER--BUT WERE PLUGGED OFF AT THE SHOWER HEAD AND THE FAUCET UNTIL THE TILE IS INSTALLED. SOOO ALL MY HUSBAND HAD TO DO WAS TURN OFF THE WATER IN THE SHOWER. NOW WE HAVE PLENTY OF HOT WATER, NO WARM COLD. YEA!!!
Jul 06, 2009 | Whirlpool Water Heaters
Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S Logo
305 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
