Question about Maytag Neptune MAH5500B Front Load Washer
I have a maytag 9000 washer with steam. I get a f 20 code. what I
Do toget it back to work? I have unpluged the machine and restared it . It worksfor a while (few min) and then goes back to F 20
SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Posted on Aug 18, 2008
TheMobilian
  • 8220 Answers
SOURCE: My maytag performa model number Pav 3200 IS SMOKING
Pump locked up Tip the washer over and take the belt off. try to turn the pump both direction. look for seperation in pump seal. Very easy to replace. Tools needed 3/8th nut driver. water pump pliers. pump is 30 bucks
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 17, 2008
FAV6800AWDIY
  • 526 Answers
SOURCE: I own a Maytag Neptune top loading washer w/ LCD
Hello camiaryan, I’m an owner of the FAV6800A LED flavor of the machine. I’m not a repair person just an owner with some basic knowledge and I’ll offer some thoughts. Checking 120VAC power to the outlet is a good 1st step. You could have a tripped a breaker but you may have checked that already before posting. There is no in line fuse in the machine to open and cause loss of 120VAC to the machine Control Board or other 120VAC components. I’m an electronics technician by craft skill training so my troubleshooting approach is technical. This machine model like most machines has it’s design issues. One of which is the bleach dispenser proximity to electrical contacts and components (Left Hand Lid Lock and the TDS). Take a read at this repair persons issue with a customers machine an FAV9800A your machine model….Maytag T/l NEPTUNE pulling info for troubleshooting with this person was difficult which prolonged troubleshooting from a distance. His symptom was no LCD display. I suspect you could have a similar issue and replacing the Console LCD panel, Control Board TDS etc. did not restore machine operation. We had to get into some good old fashion troubleshooting. The problem turned out to be severe corrosion at the plug end of the TDS (Tub Displacement Sensor) sensor going back to the Control Board. The +12VDC power on the Control Board was being pulled down by this resistive corrosive path caused over time by the location of the bleach dispenser. I’m not saying this is your issue just letting you know of a possible issue. If you are not a technical person maybe a relative or friend can help you. It might be hard for a repair tech to troubleshoot an issue such as this. The Control board and Console just for cost reference. I would not replace any components before proper troubleshooting was completed. Here is the Service Manual for our machines FAV6800A and FAV9800A yours. Here is a link to the schematic for your LCD version of the machine series 10 shows the LCD schematic. The schematics are all very similar. They are in .png format I have converted to PDF if you need just let me know. Wiring information (series 10)
Wiring information (series 13)
Wiring information (series 15)
Sears Parts Direct for reference.
If you want to troubleshoot and if I can help just shout out…..Rich
Posted on Mar 06, 2010
SOURCE: maytag performance series washer model mhwe500vp stops mid cycle
having the same problem found in side a small black hose with a small hole in it but have no idea what this hose is for. may be it is connected to some water sensor.
Posted on Jun 07, 2010
  • 1382 Answers
SOURCE: maytag epic z washer error code F21-have unplugged
F21 indicates a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump.
You may have something getting caught in the pump impeller and slowing it down. Or, you may have something clogging the drain lines. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If this solution doesn't solve your problem, you may have to replace the drain pump.The error code will continue to appear until the pump is replaced.
Thank you !!
Posted on Aug 01, 2010
Maytag 9000 series with steam washer door is locked
Unplug for 30 seconds. Plug back up. Then power it up. Should unlock. Try it again and if the error returns, it could be the motor or motor control unit, (mcu). Mody common is mcu
Aug 13, 2018 | Maytag Washing Machines
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Maytag 9000 washer series manual
the hinge on the door is broke the door is about fall off
Feb 03, 2012 | Maytag Washing Machines
My MAYTAG washer 9000 series with steam is flashing F21 and won't drain?
F 21 means slow drain if you can here the pump that means something pluging it. remove lower kick plate . the pump will be there remove cleanout counter clockwise turn .put back together.. hope this helps...good luck
Feb 01, 2011 | Whirlpool AWM9000 Front Load Washer
Same problem but I have a 3 week old maytag 9000 steam dryer, ran for a few minutes then turns off and display reads F 70
From everything I have read on the F70 code (can't seem to find an exact explanation of what it is) It seems like people are getting replacement dryers due to a electrical problem within the dryer control circuitry. Since it is only 3 weeks old, get it replaced. Good luck
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code error f07 indesit washihg machine
Per Maytag, they suggest you unplug the washer for 20 minutes and see if that resets the circuit board.
Jan 14, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
