Question about Goodman CKL30AR30 Air Conditioner
Where are service valves on a goodman model#cpj24-1ab?
    President:
  • 1,515 Answers
Hi, the service valves are on the outdoor condenser at the bottom where the 2- copper lines come out, right there. They will have 2- 1/4" caps on them and that's where the gauges connect.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
PS Please, don't forget to be kind when rating as I know you will!
Posted on Aug 02, 2010
  • Robert Horton
    Robert Horton Aug 02, 2010
    PS, if you have a package unit, look for 2- 1/4 " threaded fittings with plastic screw on caps or brass caps on them, by the compressor soldered on the copper lines. You will need to remove the panel to see them by the compressor.
    Shastalaker7
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
Goodman model gmp100 board showing 5 flashes
False flame sensed, check for sticking gas valve.
Jan 06, 2010 | Goodman Heating & Cooling
Model #GMPN100-4 Goodman furnace. Vent fan
The sequence of events for furnace operation is -
Fan purge for 30-45 seconds. During this time, a pressure switch is actuated by the running of the purge fan, proving the control board the purge fan is running.
After purge and purge prove, the hot surface ignition and or spark begins. After a few second delay, the gas valve will open. The control board then monitors for flame prove through another sensor located near the burners. If there is no flame within 3-5 seconds, the gas valve closes. It will repeat this process, usually 3 times, before it shuts the system down, which requires a power down of the system to reset.
I have seen trash get into the hose between the purge blower and the purge switch. But you could be having other problems.
Dec 17, 2009 | Goodman Heating & Cooling
CANT FIND THE CODE TO TUNE IN MY SKY REMOTE,MY TV IS A GOODMANS LD3266D
On your sky remote press interactive-skyactive-help-set up my remote follow instructions. If your Model No not on list keep checking for updated info. If no joy then contact goodmans customer services.
Sep 16, 2009 | Goodmans Televison & Video
We live in SC, have a Goodman 4 ton split system w
First of all is this unit a heat pump i'm not up on goodman model #'s if it is a heat pump reversing valves do go not a real common problem 1000.00 is excessive i would be inclined to get a 2nd opinion. plastic over the sand could create a condensation mold problem. Good luck. Tom
Jun 23, 2009 | Goodman CLQ36AR49 Air Conditioner
Compressor noise
I the compressor is bad it will draw high amps. If the amps are ok then i would look at the valve.
Jan 18, 2009 | Goodman CLQ36AR49 Air Conditioner
Service manual for Goodman Heater # PGB036100-1
sounds like that model # is for the A/C coil or its a heat pump air handler. In any event I am not aware of any "repair manual" that is put out by Goodman to the public. They have classes on their equipment but they are geared to the professional serviceman.
If you would like to descrobe the problem, I will try to help you.
Nov 03, 2008 | Goodman GMS90703BXA Heater
Goodman CKL30AR30 Air Conditioner Logo
180 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
