Air Conditioner comes on but outside fan wont start unless I manually start it....how do i replace capacitor and how would I know if it is a capacitor issue? Please Help
  • 674 Answers
First mark the wires and make a diagram so you can reconnect it. Next remove the capacitor. You can take it to a heating and air supply and they will test it for you. They will also sell you a new one. Use your wiring diagram to reinstall the capacitor wires. It sounds like your problem is the capacitor.
Posted on Aug 02, 2010
  • fkfrnndz Jun 27, 2011
    tried that solution on my unit fan would not turn at all with new capacitors 2 sets of them. Started fan manually for a few days now won't turn compressor shuts off in 10 seconds or less.
Rudd air conditioner outside fan won't start
I just had the same problem. I replaced the motor with no luck. It turned out to be a bad capacitor. If it is a dual capacitor, three prongs on top, it also starts the compressor. It is recommended to replace the capacitor anytime you replace a motor. I would try replacing the capacitor first. It is a lot cheaper that a new motor. If that does not fix the problem then you can get a motor. No harm, no foul. The slow start of the motor is a common symptom of a bad capacitor. The motor is not getting enough voltage. The capacitor increases the voltage like a transformer. It will boost it to almost 400 volts, depending on your unit.
Jun 21, 2012 | Heating & Cooling
I have a carrier 38ckc030 air conditioner. the unit outside is not turning on. it sounds like it wants to and if you manually spin the fan it will slowly build up speed, but the air coming into the house...
you are right replace the compressor/fan capacitor this helps compressor/ fan start its the round silver or oval part in the condensor ..let me know ..good luck/joe/
Aug 26, 2010 | Carrier 38CKC030 Air Conditioner
Fan wont come on outside
Ifthe compressor comes on but no fan.
Feel of fan for excessive heat
Check fan for replacement.
Also check fan capacitor
If compressor and fan don't come on check voltage
and check double capacitor
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 05, 2010 | Goodman CLJ36AR42 Air Conditioner
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Ruud 10 seer fan outside made low grinding noise then stopped working.
Bearing bad in motro or possible bad capacitor. Hard to say unless you know how check capacitor and fan motor. Price on cap replacement about 150 Fan motor abot 250 to 300 with new cap. Ask for free estimate before you commit. Russ
Jul 18, 2009 | Ruud Matching Split Air Conditioner
Ruud Achiever 10, outside Fan wont spin unless I help it.
The part you are talking about is called a capacitor. They come in various voltages and ratings. The best thing to do would be to find the rating tag on the motor, and look for the capacitor rating. There are many, many different sizes and types, so it is best to consult a proffesional before attempting to replace it on your own.
Jul 06, 2009 | Ruud UBHC Air Conditioner
My air conditional unit outside ,fans turns on but the unit compressor wont turn on,just stopped working this morning.i turned the thermostat to 72 but only the fan on the outside unit comes on and it is...
Somethings aperson cant fix without a service tech. First it could be wire burnt of capacitor going to compressor. Second it could be bad capacitor. There is a dual capacitor on the ouside unit one side says herm that runs the compressor. Turn power off to check to see if wire is burnt of the herm terminal or the C ternminal. Wire burnt off compressor common terminal.. Could be locked up compressor. Unless you know how to troubleshoot unit. You may have to call service tech. Cost if bad cap. is about 100 to 150. But unit wont run without it. Rus
Jun 21, 2009 | Emerson Quiet Kool 12HT13 Air Conditioner
Heating & Cooling Logo
195 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
