Question about Saeco Gran Crema Espresso Machine
I have a seaco gran crema and steam leaks out of the wand and where expresso comes out can someone tell me what this problem is. thanks
SOURCE: steam wand not working
When I got my X1 (used,) the steamer was clogged. I unscrewed the end of the nozzle, and a big chunk of calcium(?) came out. I had to poke it with some wire with the steamer on. The way I got the end off is: I wrapped it with a leather glove first, then turned it with a pair of pliers. I still managed to scratch it a little bit though. Maybe you can turn it by inserting a needle in the little hole on the side of the nozzle. I've been thinking of using distilled water to avoid the calcium build-up in the future.
Posted on Oct 08, 2008
SOURCE: water leaking from steam wand when brewing shots
Try this from another post. It should help.
The steam wand began to seriously leak but a call to Starbucks Customer Service line and I was talked through how to adjust it so that the leaking stopped. It requires taking off the top/back panel of the machine (6 philips screws) then using a small allen key (1.5 mm I believe) to loosen and adjust a plastic oblong donut-shaped thing (a "cam" actually) on the shaft of the steam knob... no more drips.
The key to prevent dripping is to open the steam knob without putting pressure on it when it gets to the full-open stop position. Cranking it too hard when it comes to a stop in the full-open position will slowly move the cam out of position. Then the shaft doesn't fully seat inside the machine anymore and won't fully shut off the water to the steam wand. Then, no matter how hard you crank the knob in the shut-off position it will still drip. The purpose of the cam is to stop the knob from complete unscrewing and it also turns the pump on and off for the steam wand. The cam adjustment is very small but completely solves the dripping problem. Seeing inside the machine made me realize how easy it would be to repair problems as long as I can get the parts from Starbucks or perhaps Saeco.
Posted on Dec 29, 2008
  • 14 Answers
SOURCE: Starbucks Barista Espresso Maker
This is a general comment for people having problems with leaks and pressure in their espresso machines. If you do not used filtered water, the minerals and other materials suspended in the water will bond to the moving parts and tubes of your machine (e.g.: scale). The problem will be worse if you live in an area with particularly hard water. In some cases the pressure pipes can get completely blocked and if the pump is powerful enough, the pipes can rupture, otherwise, the pump will simply not put out any water. The solution is to regularly flush out the system with descaler. The frequency of cleaning depends upon how often you use the machine. You can get descaler from any decent coffe place (like Starbucks), an appliance repair place, or the hardware store. I use CLR which is sold at hardware stores. CLR stands for Calcium-Lime-Rust, and it effectively cleans all of these and is cheaper than specialty scale removers. Simply dilute some in water and pour the mixture in the machine, then cycle the pump and run it through. Collect the spent liquid and run it through again 4 or 5 times (or more if you've never cleaned your machine before...) Allow the liquid to sit for 10-15 minutes between flushes so that the solution has a chance to eat away at the scale. Once you have done this a few times, flush out the machine thoroughly with clean water 4 or 5 times, using CLEAN water each time you rinse. If you want to get an idea of the scale that has been removed, keep a small amount of the original clean solution in a glass and then compare the spend cleaning liquid with unused cleaning liquid to see the difference. The spent liquid should be foggy/muddy compared to the clean stuff and if you let it sit, the scale will settle to the bottom of the glass and will be clearly visible. You can prevent some of the buildup in your machine by using filtered water as they do at Starbucks.
Posted on Jun 05, 2009
EsWorld
  • 1618 Answers
SOURCE: leak in steam wand
Remove screws in the grinder(2), then the one in the back you will need a long screwdriver for that one, there is one under the water tank, and there are 2-3 in the front of the machine behind the door.
Posted on Jun 09, 2009
SOURCE: Saeco Gran Crema 2 cup expresso machine
I bought t he second hand Saeco gran crema,
espresso machine.
If you have manual to send me I will appreciate
very much
Goran
Posted on Jun 11, 2010
Hi! I have a "Saeco gran crema de deluxe". When I turn on the machine, water basically immediately starts to flow out of milk frothing "thing" ("steam pipe"). not a lot, but when making espresso lots of...
Hi
not sure if that model has an electronic or manual steam valve - if electronic, it may be leaking slightly. If manual, its either not being turned right off or it also has a leak which allows water to get past it... eg - a leaking tap.
Ring your Saeco dealer, explain whats going on - should noit be too much to have fixed.
Cheers
Mike
Nov 27, 2017 | Saeco Coffee Makers & Espresso Machines
Do you fill it up with milk?
only fill with water , use the steam wand on the side to steam milk in a caraffe or small bowl then pour coffee into milk after your done.
Oct 21, 2013 | Saeco Gran Crema Espresso Machine
Solis crema sl 90 the steem is not work
Usualy this a goggle steam wand. So you can insert a thin steel wire in the seam wand and turn the steam knob slowly untill you see some steam come out. Keep move the steel wire and after you get the first steam try to boil a glass of water and leave it for ten minutes and then boil it again. This will clean the steam wand internaly.
Sep 06, 2011 | Solis Crema SL-90 Espresso Machine
I have a Seaco Royal Professional coffee machine and it is telling me to ventilate, what does this mean and how do I fix this problem?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out. This mean that any steam or air blocked in the water system must get out from steam wand.
Good luck
Jul 26, 2010 | Saeco Royal Professional Espresso Machine
One side of the expresso machine is not working
Check the nozzle at the end of the steam wand, use a paperclip to clear, if you can get hot coffee then the steam wand is just blocked.
Oct 26, 2009 | Astoria Compact CKXE Espresso Machine
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Saeco Gran Crema Espresso does not pump water
The machine needs to be primes.
Please trie and release hot water though the steam nossle.
Do like this
Open the steamer and then trie and make a cup of coffe. this will make the hot water come out thought the steamer instead of the coffe outlet.
Why you should do this is becuse the machine has it alot more easier to prime it self though the steamer then the coffe outlet.
Jun 21, 2008 | Saeco Gran Crema Espresso Machine
You can contact saeco usa .Log on www.saecousa.com and call customer service.
Sometimes saeco have the same machine manufactured also for Starbucks.All the starbuck machine have on line manual in Pdf.
Jun 18, 2008 | Saeco Gran Crema 2-Cup Espresso Machine -...
Saeco Gran Crema Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
