You need to open your PDA and check for a false contact between the connectors of the LCD screen and the main board.
Other cause may be that the LCD screen flat ribbon cable is defective.
Either problem requires to open the PDA to check it.
If you have experience in opening electronic devices then you can try it. Otherwise, I do recommend you to have a experienced technician in checking your PDA.
Im having same problem as bexta27783.I also cant access the music I download to my Nashi. I have a...
(More)
Im having same problem as bexta27783.I also cant access the music I download to my Nashi. I have a utilities disc and it doesn't work. What am I supposed to do with it?
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a...
(More)
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a reboot, the initial screen appeared, then it frozed and then it just went blank. The battery was fine but the iPAQ just won´t turn on. I returned home and immediately plugged the AC charger and nothing happened. Something similar happened a couple of weeks ago while I was outta my house and as soon as I returned home I plugged the AC charger and the LED that indicates "battery charging" started blinking, so it worked that time, but today it just does not work.
What can I do? I had a lot of stuff there that I need to access...urgently. Please help. Thanks a lot.
