Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refreg not cooling
Model number 106.53622300 not cooling
    President:
  • 1,099 Answers
If your refrigerator cooling doesn't seem to be working well, and you have no idea what to look for in troubleshooting your problem, there are some things you can do to try to figure out your problem without paying a serviceman to come into your home.
Freezing
Most new refrigerators come with automatic defrosters. Although this is a standard feature the drain hole in the defrosting assembly can get clogged with debris, lime, or even ice. If this happens the defrost will not work and there will be a build-up of ice in your freezer that begins to block the freon from flowing properly and causing heat to react improperly and cause your refrigerator to stop cooling.
Freon
Freon systems in a refrigerator are closed systems but on occasion you may need a recharge. Refrigerators use R-134a freon, just like in an automobile. The old R-12 freon is no longer available, so if you have an older model of refrigerator you will not be able to obtain the freon, and it will be recommended that you replace that refrigerator.
Seals
The seals that are on the door of the refrigerator and freezer can dry rot with time. When you begin to see the seals cracking or warping, if your refrigerator opens more easily than before, or if you see the the door does not close fully without pushing on the door then the gaskets around the doors will need to be replaced. They are held in place by clips and the replacement is an easy fix.
Holes in Lines
Let's face it, many people find ice in their freezer or the back of their refrigerator and will try some self-help without knowledge. They will grab a knife or fork and start chipping away at the ice. This is extremely dangerous. There is a great risk of puncturing a hole in the freon lines by stabbing at the ice. Since freon has the purpose of cooling most ice collects the thickest on the inside of the walls with the freon lines right behind the plastics. A better method of removing the ice is to empty your refrigerator, turn it off and leave the door open. If you want to speed up the process you can turn on a blow dryer and aim it at the edges of the ice. If you aim at the edges you will warm up the ice and create warm water which will flow down and help to separate the ice panel from the wall.
Uneven Refrigerator
If a refrigerator is not even on the floor it may not close properly. Rock your refrigerator and see if it seems to topple from one foot to another. The feet on a refrigerator can be adjusted by screwing in or out and leveling each foot individually until they are all even.
Non-Problem Warming
If your home is hot your refrigerator will work harder. If you put a lot of food in your refrigerator and freezer, your coolant will have to work harder, and it will seem to take longer to cool. It is just that there is a lot of food that is trying to freeze or maintain cool temperatures.
Hope this helpout...
Posted on Aug 02, 2010
I set the temp on refrigerator side at coldest 24 hours ago and the reading is only 42 my frig is only 2 yrs old . I looked at the other solutions none of them fit.
Posted on Sep 01, 2010
    Habit-Forming:
  • 13 Answers
Turn "off "your refrigerator and open all door for 3 - 5 hours and after this time turn "on" if your will work OK for 2- 3 days you have problem this happens the defrost will not work and there will be a build-up of ice in your freezer that begins to block air passing to cool or can be not working fan inside freezer
Posted on Sep 19, 2010
Kenmore refrigerator(model 10653606202) freezer is cooling, can hear the circulation fan' noise, also see defrosted water in the bottom collection pan. but the refrege is not cooling.
If the freezers is freezing everything and you can hear the circulation fan, maybe it is a defrost problem. Sometime ice will build up behind the rear panel in the freezer section that blocks either the chilling tubes to the refrigerator section.
You will need to remove the food from the freezer, then remove the shelves and inside back panel of the freezer. If you see a lot of ice, that is probably your problem. DON'T use water to defrost, either unplug and let it set with the door open or hurry it up with a hair dryer.
It also means your defrost assembly has stopped working and will need replaced, but the unit will work without it for several weeks before the ice build up redevelops.
Jun 07, 2011 | Refrigerators
Water cond. inside the refreg.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Whirlpool Refrigerators
Freezer is frezing but refreg side is not staying cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
May 03, 2011 | Refrigerators
How to repair a clog dain line. side by side ge refreg.
heatman101
Apr 29, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Frezzes but refreg not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 02, 2010 | Dometic RM2193 Compact Refrigerator With...
Freezer side constant 40 degrees.refreg.side 60 degrees. frost build up in freezer side in back of freezer. this problem has been constant for more than 24 hours. tom murray
om I know that refrigerator and if you will follow these simple instructions we will get you solved.On the PSS26MSrss Profile/Artica. you hardly have a defrost time issue when you seee frost on the rear panel. Unplug and make sure the model number is what is listed here and I will tell you how to fix it. OK?, Sea Breeze
Jan 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My samsung refreg. is not cooling
may be the gas has been link in a pipe line out of the line, remove it and fix another.
Oct 16, 2009 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
1,413 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
