Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Did not filtering added salt destroy the electrolitic cell in my model 8110 salt chlorinator?
  • 297 Answers
You probably didn't ruin it, just caused it to not know what to do.
In my opinion your problems started with actually being low salt.
In a panic and not realizing the proper way to test for 3000ppm you were probably low
you then got the new unit and were ready to have the same problem
If you do have high salt ( over 3500 ) you can create calcium on the plates and render them impossible to correctly read therefore giving alarms. you can also create severe corrosion on metal ladders thus putting metals in your pool and creating a new problem. Your pools chlorine will get eaten away quickly by the metals and with low or no sanitizer you will go green very fast.
So did you ruin the plates with high salt? I dont believe so. Your pool just wasnt in line abd if you had cleaned the plates with the vinegar treatment you still would have been in the same boat
all of the intex chlorinators are made the same but they are not exactly calibrated the same. They are close but not close enough so were one system might read the salt content ok the next may not
I am not sure if you were using any test kit at all but make sure you stay away from the salt test that reads in colors. The # test kit is right on the money where as the color one just gets you in the ball park
You must also remember that when it rains or you ad water because of splash out you may go low on salt. Just remeber 3000ppm
it takes a lot of rain or frsh water to alter your salt content but again if you are more on the low side of the 3000 then you would need to ad salt sooner
Please go to my name and look up my other posts dealing with low flow and gowing green
I am sure you will learn quite a bit and it should help you to have a more pleasurable experience with your pool..
start using the chemicals I mention in those posts cause once you go green it is hard and back breaking to get your pool back to clear
Posted on Aug 02, 2010
Testimonial: "you're the BEST - have learned a GREAT DEAL about my salt water chlorinator - MANY THANKS!!!!"
  • mark Gianotto Aug 02, 2010
    You are very welcome.
    Glad I could help you out
    Mark
  • mandretti Aug 04, 2010
    got my water tested as 3800 ppm! pool store sold me chemicals to shock the water and suggested the salt chlorinator may not be able to sufficiently bring the water up to proper levels (which is why all the chemicals are required when pool first opened) but able to maintain proper levels once reached. these are the chemicals i was told to use:
    ph, uv block, amaze plus (shock?) - what do you think. regarding the plates- should i clean everything in vinegar again? do you think the chlorinator will start to work once i get the pool levels right? thanks in advance - Mary
Crystal clear model 8110 service light came on. How do I fix so will chlorinate again?
is your salinity correct? (salt) clean sensor then clean cell with either cleaner or 4 to 1 ratio of muriatic acid and water 4 parts water then see if it works make sure water is perfectly balanced
Aug 07, 2014 | Pool & Spa
Salt Water System Model 8110 will not generate Chlorine
6000 gallon pool initial salt 129 lbs for count of 3000 ppm
Mar 05, 2017 | Intex Automatic Salt Water System for ...
We have a 18x48 ultra frame intex pool. It at first gave us a lot of problems saying low salt so we cleaned the cell with vinegar and it began working no probs for the past 3 weeks. On the weekend I went...
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Aug 09, 2011 | Intex Automatic Salt Water System for ...
WE ADDED FOUR 40 LB BAGS TO 18 X48 EASY SET POOL AND STARTED UP THE SALT WATER CHLORINATOR THE NEXT DAY . THE CODE FOR HIGH SALT CAME UP. WHAT SHOULD I DO? ALSO WHEN THE CODES POP UP DOES THE CHLORINATOR...
Start buy draining 20% of your water and adding fresh.
Filter normal for about 12 hours.
Now test your salt PPM
You can get a salt test kit at any pool supply
you want your salt ppm to be as close to 3000 as possible
any lower than 2700 and you will not produce enough sanitizer and over 3500 can produce high salt code, just taste bad, and ruin your cells in the unit
As for not working, yes the unit will not function properly with any code that comes up
Jun 14, 2011 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
Constant code 91! after only 1 week my first chlorinator was replaced due to this code. Have been using my replacement for approx 2.5 weeks and got my first code 91 - added 1 bag of high purity pool salt...
A few things to do or you will create your own problems.
First and for most you must filter for at least 12 hours after adding salt to distribute the salt completly
You can not just blindly ad salt like you said you added a bag.
Although the manuals have an amount of salt for different size pools it is just a starting point. It is up to you tp fine tune
you must get a salt test kit
the kind that reads #'s not color
Get your salt as close to 3000ppm as possible
any lower than 2700 and you will get a low salt alarm and you will also not be producing enough chlorine
any higher than 3500 and you can go cloudy, trigger high alarm, and the water will taste nasty
you can even trigger low salt with too much salt content
So remember 3000ppm
If you are higher than the 3500 then drain 20% water and fill with fresh
continue this until you get to close to 3000
If low follow directions for low salt either on the test directions or bag of salt
I have had my system for this being the 4th season and have never cleaned the cells
any way, when you get the pool to around 3000 filter only for about 12 hours then turn on your generator
It should work fine
Aug 01, 2010 | Intex Automatic Salt Water System for ...
Do I have to drain my 24 ft round above ground pool to install an intex salt-chlorine generating system? I have just opened he pool and the ph and chlorine levels are where they should be.
no need to drain go to the intex web site and look up your pool size for the starting amount of salt you need.
After ading it run your filter for at least 24 hours before trying to generate use this web site and click on the english version for pump 8110 once it downloads go to page 13 14 15
to find the salt amount you need
chlorinehttp://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Jun 06, 2010 | Intex Automatic Salt Water System for ...
This is my 3rd year using intex 8110 sytem. I
That code means the unit is in standby. It should start working if you set the opperational hours that you want in the program. Use the program guide in the manual.
Please Vote !!
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator not producting chlorine
You can test if the 8110 is generating any chlorine by taking a water sample directly at the pool return. You can invert your container so it stays filled with air until you have it positioned in front of your return. Make sure your test chemicals are not expired and test the sample. You should get a high reading if the 8110 is producing any chlorine. If it is producing chlorine, you may want to make sure you have the correct level of Cyanuric Acid. In my pool, if the Cyanuric Acid level is low, the chlorine level drops to zero quite quickly.
If the sample indicated your 8110 is not producing any chlorine, I would check to see if you have approx. 24V DC between B+ and Gnd on the screw terminal strip on the main circuit board. The transformer supplies two voltages to the 8110. One voltage powers the electronics and the other powers the electrolytic circuit. So it is possible for part of the unit to work if one voltage has failed.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
310 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
