Question about True T23 Refrigerator
We have a T-23 and it was getting to the 38 degree mark on the outside temp gauge, but today it wouldn't reach that. It felt cold inside, but I haven't put an inside gauge in yet. We have just purchased this consession trailer. Is there something we need to check for that would make the refrigerator do this? The trailer isn't perfectly level, does this matter? It is an electric, not gas refrig.
  • True Master
  • 1,266 Answers
If it's location is new, you may have it positioned in such a way that the air around the condenser is not moving. You must have circulating air all around the compressor compartment.
Posted on Sep 29, 2017
5 Suggested Answers
charcois
  • 763 Answers
SOURCE: commerical reach-in problem
try by defrosting it all and remove what store inside. after that start it again and see if it the same problem happening.
thank you for using fixya
CHARCOIS
Posted on Nov 24, 2008
MNfisherman
  • 11896 Answers
SOURCE: Freezer & freezer work fine.
It may have auto-defrost or frost-free feature that is not operating. Also there is a drain tube that goes from the compartments to the bottom of the fridge where the evaporator pan is. The tube may be plugged.
Posted on Jul 02, 2009
dmftrucker
  • 1922 Answers
SOURCE: My whirlpool side by side(ES5FHAXS)? quits cooling
replace the control box Whirlpool part# AP2984350 $40.00 w/shipping
Posted on Oct 26, 2009
Testimonial: "Thank you for such a quick response to my problem. I don't know if that will fix it but sounds good. I will let you know after I try it. Thank you. "
  • 112 Answers
SOURCE: The cooler will not cycle
Inside of the unit on the right side of the coil. You may need a little mirror to see it easier. There is a metal plate with a little v cut to indicate where the setpoint is and the knob should have numbers from 1 to 9. The typical setting is 5.
Posted on Jan 04, 2011
My car wont go in between the hot and cold meter
engine - Car temperature displaying below Cold or just ...
mechanics.stackexchange.com/.../car-temperature-displaying-below-cold...
Jun 25, 2012 - Today I was boiling inside my car as it was a very hot day and my ...cold, it almost never goes up to even 1/4 of the temperature gauge, the ... Where I live, it's hot enough that even with the thermostat wide open the engine won't stay at C.. ... How to Match Skin Color Between Pictures Of The Same Person In ...
What does it mean when my car's temperature gauge is halfway ...
https://answers.yahoo.com/question/index?qid...
Aug 23, 2011 - I think my temperature gauge is usually all the way to the left, which I think is "cold" (okay). ... before steam poured from under the hood of my car and I had to pay $217 ... Why does my A/C stop blowing cold & my temperature gauge goes toHOT? ... But the battery won't keep a charge after sitting over night. my temp gauge always stays on cold. never moves.? ' Yahoo Answers
Mar 28, 2014
My car temperature gauge started going crazy and it doesnt even ...
Nov 10, 2011
My engine temp gauge reads below normal, close to cold, even ...
Mar 23, 2007
my temperature gage on my car keeps going up and down.. does ...
Feb 15, 2007
More results from answers.yahoo.com
Dec 01, 2015 | 2002 Acura RL 3.5
How do I keep my RF266AEPN refrigerator with twin cooling, from icing up on the right side. This is a problem that has frequently happened in the summertime , but now, it is happening in the fall. Thi
Did you check the door gasket see if it is gunked up or air is leaking on that side? Have you felt around the door see if cold air escape? If air is escape means you will get icing or frost.
Nov 28, 2014 | Samsung Refrigerators
Blower control
Sounds like a thermostat and/ or the system is low on coolant.
Its probably not going to reach 200 degrees when the outside air temp is below freezing, but you should get plenty of heat if the system is working correctly.
Jan 23, 2014 | Pontiac Grand Am Cars & Trucks
2000 nissan altima blows cold until outside temp reaches 90 degrees then blows hot
2000 Nissan Altima Heater Air Condition Section HA 76 pages Here is factory service repair manual for your vehicle . Do you know how to do testing on these system ? Automotive electrical system testing ? How to read a wiring diagram ? When hot outside is the inlet pipe to evaporator freezing up ? Do you know where this is , under the hood in the engine compartment at the fire wall . What are gauge readings , Is the compressor engaging ? Were any switches replaced ? Ambient temp. , thermal transmitter switch . pressure etc...
Apr 25, 2017 | 2000 Nissan Altima
98 BUICK REGAL GS AC compressor will not come on. It has the climate control unit. All the lights and fans work and there is enought freon. The display reads -38 degrees for the outside temp. Would this...
If the outside temp.sensor is reading -38 degrees then this is what is causing the compressor not to come on.You need to check the wiring to the outside temp.sensor and the sensor.Make sure it is connected.It is located on the front grill area.Between the grill and the bumper cover.Hope this helps.Good luck.
May 19, 2010 | 1998 Buick Regal
My compressor works itermittantly. I was holding suction line to see if it felt cold. It felt kinda cool. Then all of a sudden it went COLD. A minute or two later it was kinda cool again. Could my...
A hard start kit always helps. Take a reading inside. Temp at the return air and temp at the closest grille. Subtract and that temp should be between 19 to 23 degrees. If not you have other problems. Contact service tech for free estimate. Possibly a little low on refigerat, Rus
Jul 03, 2009 | Heating & Cooling
Ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
2002 gmc van overheatig
It has a leak. Fill up the radiator and the coolant tank. Then restart it and check for leaks.
Mar 13, 2009 | 2002 GMC Savana
Overheating/No Heat 2001 Impala
change the thermostat and the temp gauge in the radiator
Mar 03, 2009 | 2001 Chevrolet Impala
True T23 Refrigerator Logo
99 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
