Question about Video Game Consoles & Games
The adaptor for my xbox 360 has a flashing orange light and the xbox wont turn on
  • 61 Answers
You probably entered in a wrong ip address when you where setting it up
Posted on Aug 04, 2010
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Ac adaptor blinking orange. Xbox360 won't power up.
An orange light is illuminated on the power supply for one of the following reasons:
  • The console is turned off.
  • The power supply is disconnected from the console.
  • The power supply cord is not fully inserted into the power socket of the console.
  • The power supply is faulty.
  • The console is faulty. (The console might be faulty if it does not turn on when the power supply light is orange.)
Step 1: Try to connect and then disconnect the power supply
loadTOCNode(2, 'whattotry'); Follow these steps to connect and then disconnect the power supply:
  1. Turn off the Xbox 360 console.
  2. Disconnect the cord that connects the power supply to the console.
  3. Reconnect all the cords, and then try to turn on the console.
if after this also your console does not power up then you need to check if you are seeing any flashing red lights on the power button of Xbox 360, if you see the red flashing lights then you would have to get your power adaptor replaced by calling up MS Customer Support.
If you do not see flashing red lights on the console power button in that case the console itself would have to be send for repairs
Please do rate my solution, Wish you Happy Holidays and Happy Gaming
Regards
KreativeGeek
Dec 29, 2009 | Microsoft Xbox 360 Console
My xbox 360 works fine playing the games that are demos
there might be a short.
other then that i might just think that your power adapter is failing and you need another one.
Dec 01, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
My xbox 360 wont turn on al all(not rrod)
Have you fully unplugged it and as in the mains from the adaptor, adaptor from the 360 etc? then re-plugged it?
If this does not help then i think you may need to visit http://www.xbox.com/en-GB/support
Oct 29, 2009 | Microsoft Xbox 360 Console
Turns off immediately after turning on.
Try another known working ac adaptor and if you get the same symptoms then you know the system is bad, if the symptoms go away then you know its a problem with your original ac adaptor.
Jun 02, 2009 | Microsoft Xbox 360 Console
Xbox 360 adapter
The flashing yellow light on the Power adaptor points to a potential failure with the power adaptor. Usually when the adaptor is idle their is a solid yellow light, A red light for a total failure and a green light for on.
A YEllow flashing light would indicate that there could be potential problems with the adaptor overheating and/or being faulty. where is the adaptor located ? just like the console itself. they are prone to overheating and collect dust very easily.
i would suggest moving the adaptor into an area with a large opening to allow the flow of air to keep it cool, also i would attempt to remove any dust inside.
Try doing this and if the problem persists, let me know
Oct 25, 2008 | Microsoft Xbox 360 Console
X box 360
Hey tjames2ya,
If your XBox 360 is not turning on, you may wish to verify that the power adaptor is functioning correctly. The power adaptor should have a light somewhere on its casing that shows up green, red or orange when plugged in. Each of these colors is an indication of a different problem:
* Green indicates that power is being correctly supplied to the XBox 360. If the XBox 360 still does not turn on, you will need to contact Microsoft for repairs and support.
* Orange indicates that at least one connection is loose. Making sure that all of the cables attached to the XBox 360 are secure should resolve this type of problem, and allow your console to power on.
* Red indicates that the power adaptor has either overheated or needs to be replaced. If the light is out, this may also be an indicator that the power adaptor is defective, but it may just as easily be a sign that the outlet the XBox 360 was plugged into did not provide enough electricity to power the console.
Unfortunately, in order to reset the XBox 360 you will need power to be supplied to the console. If replacing the power adaptor or double-checking your connections does return power to the console, you may then reset it by performing a "power cycle" (turning the unit off, then back on roughly 10-15 seconds later).
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 16, 2008 | Video Game Consoles & Games
XBOX360
Hey 2hitz,
According to information provided by the manufacturer, when the power supply light is red this can typically mean that the XBox 360's external power supply (AC adaptor) has encountered a problem and may need to be repaired or replaced. Most problems encountered are typically limited to an issue where the system has overheated or there is too much voltage/electrical current for the power supply to handle.
I'd first suggest checking to see if the AC adaptor is properly connected to your XBox 360 or is warm to the touch. If the adaptor is hot, you may wish to unplug the adaptor for several hours to cool before reconnecting it to your XBox 360. Even if it is fairly cool, you may still want to see if disconnecting and reconnecting the adaptor resolves the issue. If the power light changes from red to an orange hue once you do, this can mean that the power supply may not have been securely attached and the unit is now in standby mode.
Next, if you have access to a second power adaptor, you may want to see if switching adaptors resolves the issue instead. If the XBox 360 goes into standby mode with a different adaptor plugged in but not the original, then the original adaptor may be defective and be in need of replacement.
Please keep in mind however, that if the lights around the power indicator light are also flashing red this may be a sign of an entirely different hardware problem. If you are seeing any of the lights in the outer ring light up, you may want to take note of which ones (and how many) are lighting up at any given time. Typically one flashing red light in the outer ring may indicate a hard drive problem, two red lights may indicate the XBox 360 itself has overheated, three red lights mean that the unit requires service/repairs, and four red lights mean that your audio-video (AV) cable isn't securely connected.
If you're still not quite sure how to proceed, you can always visit Microsoft's knowledge base website for more information and suggestions by using the link I've provided below:
http://support.microsoft.com/
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 03, 2008 | Apple iPod MA446LL/A MP3 Player
Video Game Consoles & Games Logo
27 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
