Question about Jet 3 Ultra Power Chair
Directions to replace the battery in a jet3 power
Does anyone have directions to replace the battery in a jet3 power chair
  • 692 Answers
Unplug the joystick cable under the seat remove the seat if on a post lift handle on right side under seat and lift seat off post if not look for release levers behind front seat post and seat will rotate backwards to give you access to the batteriesdisconnect battery cables and install as on old batteries to new ones and reinstall Hope this helps
Posted on Aug 17, 2010
My jet3 ultra won't stay on
Chances are you batteries are beyond their usable life and need replacement -OR- you have a disconnect between either battery and the chair. Please check to make sure the circuit breaker isn't popped, all the fuses under the shrink-wrap on the positive terminals are good and that the battery connectors are seated properly. If the batteries each measure 12-14 volts at the battery post while the chair is plugged in and either drop below 10volts when unplugged then your batteries need replacing.
Mar 07, 2014 | Jet 3 Ultra Power Chair
Need price on joystick @ power cord for jet3 power chair controller # ab0511447
About $600.00 -$700.00 rebuilt if you can find one . Try contacting Pride Mobility @ 1-800-800-8586 ask for Jazzy tech support and ask about replacement joystick and cost Hope this helps
Jun 20, 2011 | Jet 3 Ultra Power Chair
CAN'T LIFT OFF SEAT OF JET3 POWER CHAIR? batteries
Richard The seat is probably rusted on the seat post It will take alot of turning and pulling upward at the same time to get it off. Try spraying a penetrant on the post just below the seat to see if that will help with the turning and pulling just keep at it. It can be a tedious task and frustrating Hope this helps
Mar 16, 2011 | Jet 3 Ultra Power Chair
Unit charges shows full and by mid day in a nursing home battery lights show only 2 red lights. do i need to replace batteries. the chair is a jet3 it was bought in 2003 and not used for about 2...
You definitely need new batteries. There are 2 size U-1 batteries in the chair that will last between 1.5 and 2 years. Get the deep cycle sealed gel lead acid batteries, preferably AGM. Hope this helps.
Feb 15, 2011 | Jet 3 Ultra Power Chair
How do you know if the battery is charging.
To find out if your battery charger is working on your jet3 .
First thing you do is make sure its plugged in
Second locate your meter next to the plug on your chair
Third when plugging in the cord make sure your meter moves to the center of the meter.
If this works congrats your charger is working.
Jan 22, 2011 | Jet 3 Ultra Power Chair
Jet 3 will not charge.
you need to go to the store u bought it at and ask them
Feb 14, 2010 | Invacare Pronto M51 Power Wheelchair
With a full charge chair stops working and won"t power up
I have a Jiffy Jet3 . the problem is when I charge the batteries
the light indicator just blinks but chair doesnt run.
I just put new batteries and still doesnt run,,,thanks J.J.F.
Feb 12, 2010 | Jet 3 Ultra Power Chair
I just bought a jet3 ultra and it looks new, but battery is dead. How long should I let it charge up? I have the power cord. Do you have it sit in it to make it go? How do I get it to go?
If the battery is dead I would have the batteries load tested. Let it charge 12-14 hours. To operate the chair push the power button and push the joystick in the direction that you want to go.
Dec 16, 2009 | Jet 3 Ultra Power Chair
Jet3 ultra power chair wont charge
If you have access to a voltmeter,put it on your battery then plug in the charger; if the voltage rises that will tell you that your charger is working.
Apr 09, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
228 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
