Question about Maytag Atlantis MAV6451 Top Load Washer
I used the washer after several months of non use. Water flooded the floor! It did drain when I put it on spin.
  • Maytag Master
  • 8,220 Answers
The water level is controlled by a switch that attaches to a tube coming from the bottom of the tub. If that tube is compromised by a hole or simply fell off the switch then the water pressure won't build in the tube and shut down the switch.I used the washer after several months of non use. - a329de6.jpgThe switch above is not exactly like yours. But it has a tubing going to it like that. Blow through the tubing to remove sediment then reattach the tubing securely. Pump out the water and then retry. No parts needed.
Rate it or hate it:1a2b3d0.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 02, 2010
Washer's external Drain hose dislodged at drain pipe, do you suspect the recent severe thumping spin cycle caused this to happen? Flooding occurred. How would you test drain hose? What could be the...
If you were flooded then drain hose does not seem to be clogged. Yes severe thumping would or could cause washer to bounce around enough to pull drain hose out. Thumping would be because of unbalanced load. Or worn dampers and/or springs. Post make and model for better answers.
Mar 23, 2015 | Washing Machines
Water fills when machine is off
I would think perhaps you need to call a repair man to have inlet valves replaced .
Sep 05, 2017 | LG WM2240CW Washer
Floods floor when on rince cycle Program Bed andBath. Fault intermittant
If you didn't flood the floor when the washer emptied on the wash cycle, it is more likely that you have a partially plugged up drain than a malfunctioning washer!
Has you drains been cleaned lately, being the spring time you might have a root problem partially blooking the drains.
Watch you washer, if the washer flushes the water down the drain line it is working. If the water comes over the top of the drain line, then you have a slow drain.
Jun 01, 2011 | Washing Machines
My washing machine will not empty of water and this is preventing it from spinning.how do i empty the water via pump filter as i have no manual and it will not let me download one.please help!
This is could be caused from several issues. First I would try changing cycles on the timer to another spin cycle to see if that let the washer drain. Some times the timer malfunctions and doesn't allow the washer to spin. If this doesn't work and you can hear the motor running then you could have a broken belt or bad clutch or a wig wag (electric solenoids that operate the transmission.). The easiest way to empty the washer if it's located near a floor drain is to remove the drain hose from the drain and lay it on the floor near the drain. The water will run right out of the machine. If you not near a drain then you can use a Wet / Dry Shop Vac, remove the paper filter from inside the Shop Vac and then your ready to vacuum out the water. You will need to empty the vac several times.
Or you can use a garden hose and siphon the water out by place in one end in the washer and the other end outside or near a drain, You will need to **** on the end of the hose that's near the drain or outside. This will almost guarantee you a mouth full of laundry water so be careful if you try this.
Aug 05, 2010 | Washing Machines
I put a wash in an hour ago and the machine has stopped and is full of water.i have made sure its not on soak and also than switched it off and put it on a spin cycle to drian all the water and starts and...
the only way to drain this water out is go to the back of the washer and pull out the out let pipe from the drain on the wall, put it in a bucket and the water should drain out most of the way,,,, at least it should not flood the floor so bad when you open the washer door
May 20, 2010 | Washing Machines
My kenmore washer will aggitate and drain but not spin. what gives?
Possibly not draining fully , so drum is too heavy to spin , check , clean and replace drain filter and try again .N.B. If there is still washing / water in the machine you need to remove this first or you risk flooding your kitchen floor.
Nov 03, 2009 | Washing Machines
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Drain old water
hi thanks for the question. to drain washer.put hose on floor in bucket. this will drain your washer thanks. for the question the appliance doc
Oct 04, 2008 | Kenmore 22062 Top Load Washer
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Feb 07, 2007 | Frigidaire GLTF1240A Front Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
