Question about JVC Televison & Video
My JVC Super Command television needs help. Everything else works but the picture. There is a thin line of color horizontally accross the screen. Does anyone know if there is a fix for this?
  • 124 Answers
SOURCE: thin horizontal line
Defective components in vertical deflection and output circuit inclusive of vertical output device, coupling capacitors, and yoke connectors. Passive devices such as electrolytic capacitors, coils, and resistors to/from power supply circuits. If your tele is more than 10 years old dump it and get a newer product. $100 USD is a fair price to diagnose and attempt service, depending on age and configuration. Older products may not have replacment parts available at any repair cost. There may be a pot for adjusting the vertical size. If so, it may be dirty. If you can find it, try adjusting it which could clean it. BE CAREFUL -voltages are very high.
Posted on Mar 20, 2006
nfandres
  • 168 Answers
SOURCE: Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Posted on Mar 10, 2007
  • 1030 Answers
SOURCE: Thin black horizontal lines on JVC PD-42WV74 EDTV
horizontal line is an idication of a bad board known as a x driver board. Their may be a slight possiblitliy it can be a small ribbion cable that runs from the driver board to the plasma panel. Another possiblility it can be a bad panel... but from the symptoms you describe i would first have to look at that driver board. and the sympton that getting worse makes me lean toward a bad ribbion cable.. if that could be reseated....well that the first thing as a technician i would try. Carefull Television generate dangerous voltages.
Posted on Jan 04, 2008
  • 579 Answers
SOURCE: Tube TV - one thin horizontal line of bright light
Vertical defection failure. Common failure. Pretty easy to repair ($50-75?). However, my general rule of thumb is not to waste any more money on TVs over 10 years old. Too much other stuff in there ready to fail as well.
Posted on Jan 24, 2008
  • 36 Answers
SOURCE: PICTURE IS ONLY FINE HORIZONTAL LINE
Hi there,it looks as if you have a frame collaps,this is the first time i have ever heard of this on an LCD tv,i take it that there is no picture at all only a thin line.
Posted on Feb 03, 2008
How do I fix a thin horizontal line near the top of my smart TV?
Live until more line appear as it will need a electronic board to be replaced.
Is the line black or colored ?
how thin and where on the screen?
https://www.youtube.com/watch?v=j7vl7-vZEL8
see attached video of another model for help. but the decision is yours
Mar 15, 2016 | Samsung 40" 1080p 60Hz LED-LCD Smart TV...
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Apr 01, 2009 | JVC PD-42DX6 42 in. Plasma Television
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Thin horizontal line across the screen
you need to replace the electrolytic capacitor in the horizontal section of of your tv sets,cause the capacitor is weak.need to repair
Jan 11, 2009 | Sharp 27C-240 27" TV
Erratic problem
need to have the vertical output IC pins resoldered.
Jun 13, 2008 | JVC AV-27730 27" TV
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
452 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
