Have installed new netgear wireless router for two-computer home network that my desktop pc 'found' with no problem (it's cable-connected) but my remote laptop can't seem to 'find.' vista shows it's connected to network but cannot identify it, thus has 'local' connection only. new network has name, password, etc; believe i followed all installation instrux properly. don't know how to get laptop to 'see' newly routered network. duh.
  • tdkliewer Aug 02, 2010
    no, seems like there must be some way to get the laptop to accept the new name of the network. right now, it shows the network as 'unidentified,' which it isn't. it has a name and password, which laptop accepts and shows as having used to make connection but, alas, has not, in fact used to connect.
  • 12,061 Answers
OK, TURN OFF DHCP, in Services, on BOTH PC's.
Also you MUST have a password on BOTH PC's BOTH must be in the same workgroup, both PC's should have sharing enabled on the folders/drive you wish.
Use the Network connection Wizard to connect up.
compnetworking.about.com/.../homenetworking/Home_Networking_Setting_Up_a_Home_Network.htm
windows.microsoft.com/en-US/...vista/Setting-up-a-home-network
These above links will help.
Posted on Aug 02, 2010
  • 4,924 Answers
Try to reinstall the laptop's wireless card ....maybe you have a problem with that ..also see that the card is turned on from the button ..and when you open the wireless window..just click on scan for networks ..and it will find the router by the name you assigned..and ask for the password..
  • Catalin Turcu
    Catalin Turcu Aug 02, 2010
    try to change the frequency in the router settings on the wireless..section ...see that it has numbers o a scale from 1 to 12...or so ...put it in the middle about 8 or 9 will be better ..and than try again ...Be sure that you did not set on security to (in the wifi setting are ain the router ) select the connections by the MAC address..cause in this way will refuse the connections but for the mac adresses you selected..
    If I was in your place I will remove any security for the moment ..and name ,,,and practically reset the wifi settings in the router to the initial ones..and just enable it and select a frequency in the midle of the scale ...and see if it works ..
    These routers only have a 100m range or so anyway ..and if you do not have any body on that range it will not be able to get your signal ...and after you see that it works ..than you select a name or a password for it ...it may be the case that the encoding that you chosen for the password not to be compatible with the card ...or maybe the router is on N and the laptop on G ....
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
Have wireless broadband on home computer with Netgear dont have network key which I need to connect new laptop to wireless broadband Bt of no help and cannot give me a no fo Netgear either even though Bt...
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 19, 2009 | NetGear DG834G Router
A random guy came in and setup a home network for us using a Netgear Wireless router (WGR614v6). We have a PC on main level, an iMac and laptop in the basement that connect wirelessly and without any...
Hi whioch computer has a problem ?
A PC with the new hard drive ?
Mkae sure that you have the wireless adapter working on the computer.
If it is working then try to find the network .
Click Here for more info about wireless network.
Oct 08, 2009 | NetGear WGR614 Wireless Router
I got a new router (Netgear W..8.)for my home
try puuting the wireless access point on the middle and atleast 5 ft of the ground this will increase your signal slightly also make sure that there is no cordless phone especially the base near the wireless access point.
Sep 15, 2009 | Zyxel G-220 802.11g/b Wireless Adapter
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
No network detected to setup wireless router
You have to set a network connection on the computer. Go to the control panel and chose Network, the set a new one.
Jan 06, 2009 | Computers & Internet
I have 2 computers. I can connect to the internet wirelessly with the XP one through a Netgear router. My HP Touchsmart,Vista Home Premium, purchased recently,will connect through an Ethernet cable, but...
Are you sure that your PC has a built in wireless function and not just a regular modem ??
If you just have a modem you will need to purchase a USB wireless interface the link below will take you to one perfectly compatible with your router.
http://www.ebuyer.com/product/60014
Good luck ;)
Carl
Dec 02, 2008 | HP Computers & Internet
Computer cannot access the internet
Try to disable wireless card on your desktop. With both the wireless and cat-5 socket enabled, "WITHOUT" the proper bridge settings, they will conflict and not be able to read.
Apr 07, 2008 | Computers & Internet
One computer on network can't open internet pages
Try resetting the modem. It may be the Modem has to re-assign an appropriate ip address to your desktop.
Apr 01, 2008 | Computers & Internet
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
23 people viewed this question
Alun Cox
David Payne
David Payne
