Question about Grilling
MY GRILL DOESNT HAVE ANY GAS PRESSURE. IF I TURN ON ONE BURNER ITS VERY LOW, THEN IF I TURN ON 2 BOTH GO OUT.
  • 8,220 Answers
Those new tanks use a safety device that is tricky and very touchy. Remove the tank and open all the valves. Close all the valves on the cooker and reattach the tank making sure no obsticles are present. SLOWLY open the tank just a little bit and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 02, 2010
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
Low flow to the burners. Probably because of spider webs
Yes, sometimes spider webs can cause it, as well as the OPD valve in the gas tank locking up the grill's regulator. In addition, a low pressure can be caused my low fuel in the tank.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Sep 23, 2011 | Lynx L36FR (LP) Grill
Low flame at burner. I've put a new tank on my grill and now the flame stays very low on all burners. I've heard that there can be some pressure problems with a newly filled tank. Is there a quick...
Mike, there can be some pressure problems, but it's not the new tank. However, it does cause the problem and here's how you resolve it.
1. Turn the gas tank valve OFF.
2. Disconnect the hose from the tank and wait 5 minutes.
3. Reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and turn the burn to HIGH.
Does the burner light and the flame height look correct? If so, light the remaining burners the same
way. Now, do all the burner flames look as the should? If co, you solved the problem. Always
remember to turn the tank valve ON very, very slowly>
If the above did not solve the problem, you will need to replace the grill's Hose/Regulator Assembly. You can pick one up at any home center or hardware store that sells gas grills and accessories. It will run you about $30.00 (+/-) .
Hope this helped you to solve the problem Please let me know & Happy Grilling!!
Jun 12, 2011 | Grilling
My7 Baby q doesnt get hot enought to sear steaks
Their are several things that can cause this problem:
1. The burner(s) need to be removed and thoroughly cleaned.
2, Low amount of gas in the tank.
3. The grill's gas regulator is partially seized.
The first two are easy for you to solve, The third one is to if you do the following:
Turn the gas tank valve OFF. If you're using a 20lb LP Gas grill tank, disconnect the hose from the tank and wait 5 minutes, If you're using a small 1 lb cylinder, turn it OFF and remove it from the grill. after 5 minutes, reconnect the hose to the tank or reinsert the small cylinder and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open light the burner(s) and turn it to the highest setting. Did the burner light and does the flame height look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If the above didn't solve the problem, you will need to replace the grill's hose/regulator assembly (if you're using a 20Lb LP Grill Tank). Which you can find at any home center or hardware store that sells gas grills and accessories. If you're using the smaller insert-able tank, you will need to replace the tank's hookup and regulator mechanism.
Jun 03, 2011 | Weber Baby Q Grill
How do I light the grill manually
Get a butane grill lighter. Open the hood of your grill. Remove the cooking grates and one by one turn the burner to low. Light the butane grill lighter prior to turning the burner on and as you turn the burner to low touch the flame of the lighter to the burner. Leave all burners on low, until you replace the cooking grates. Be very very careful, as you don't want gas to buildup before each burner is lit.
Then contact Brinkman for replacement ignitors.
Jan 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
When I start the grill, all burners are low and will not heat more than 200 degrees. i have replaced all 3 burners and still have the problem any answers?
Hello, Turn your gas tank valve off. Loosen and remove the regulator from the tank. Wait 15 or more minutes. Replace the regulator securely in the tank valve. Ensure ALL the burner valves are off. SLOWLY, I say again SLOWLY turn on the tank valve 1/2 turn. Try the grill again. There is a safety feature in the regulator that senses a gas leak; if the valve is turned on to quickly and to much pressure or gas flow is detected it will close down and the grill will not heat up as normal.
If you find this helpful please vote yes. Thank You!
Oct 17, 2010 | Char-Broil Advantage 463453306
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
Rangemaster 110 grill flame.
to find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Dec 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
Grilling Logo
257 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
