Question about Refrigerators
My ice maker, ice and water dispensers do not work. When you depress the dispenser levers that actuate the microswitches, all you get is the residual 'click' with no electrical buzzing,etc. There are no display lights on the dispenser console. The Control panel in the cooler section of the fridge is illuminating, working and maintaining proper freezer and cooler temps and the lights in the freezer and cooler cabinets are illuminating with the doorswitches open.
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links to diagnose your problem to your refrigerator…
http://www.ehow.com/how_4708794_troubleshooting-kenmore-refrigerator-ice-maker.html
http://www.geappliances.com/service_and_support/faqs/faq_refrigerators.htm
http://www.repairclinic.com/Refrigerator-Troubleshooting#Theresanice-orwater-dispensingproblem
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 02, 2010
I have a Jenn-Air refrigerator #JCD2389DES. The ice maker became stuck and kept delivering ice cubes even after dispenser was released. I finally opened the freezer door and got it stopped. Now it...
Yes it could be either, BUT I would go back and make sure that everything you did to stop it the first time is undone. Is everything setted correctly? Is the switches in the right place?
Neither the solenoid or the microswitch could cause the problem you had before, so I would suspect something is not right with the ice maker itself.
Jun 16, 2011 | Jenn-Air JCD2295HES Side by Side...
Water button sticking
Replace that microswitch for the dispenser lever. It might not be a separate switch though, it may be part of the control board for the dispenser module. disconnect power to the fridge, remove the dispenser cover to expose the wiring, etc., determine what the lever actuates when depressed, and it will likely be the microswitch separate from the board.
Jul 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Whirlpool refrigerator ice dispenser no longer workds
HI, the Ice maker control module will need to be replaced in your unit asap if possible. this module controls and initiates the actions when the lever is depressed.
Jun 05, 2009 | Whirlpool GS6SHAXLS Side by Side...
Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Jun 05, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker makes ice, but won't dispense.
if you hear a click when the actuator is depressed the swt is ok remove ice bin and try rotating auger mtr by hand if you can't the auger motor is frozen, you can remove the whole auger asm and let it thaw out and dry out for a few days
Dec 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore Refrigerator
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Feb 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Aug 10, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
