Question about Vacuums
My dyson turbo brush won't spin, and doesn't seem to be sucking either. Not sure what to do
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Sounds like the reason the brush is not working is the belt that drives it has either split or just come off If it is not sucking there must be a blockage in the tubes simply take them of and clean
Posted on Aug 02, 2010
Dyson DC28 is not picking up anything but brush is working and there there is some suction
Did you take it to a service center that does Dyson warranty work? If not you may want to. A DC28 is not easy to work on without the proper tools and repair manuals.
Nov 27, 2017 | Dyson Vacuums
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    My dyson hose sucks good but, when i put handle down, it won't **** but brush does turn
    I just had the same problem....suction from wand, but no suction from soleplate, the brush bar spins. Did all the troubleshooting steps on dyson.com but they didn't work...dyson.com says need to take to repairman, being a diyer I went to search engine. I didn't find a fix, however I found one myself....it appears the vac can get stuck in floor mode or in between modes....the dial on top on dc07 ....selector of floor or carpet..try pushing it back and forth to see if that puts it in carpet mode...check for suction or try vacuuming...if that doesn't work, looking at vac from behind vac on the right hand side is the selector dial..on top of bottom portion of vac.....with vac in upright position, recline it as if about to vacuumn floor...look down at selector area ...you should be able to see a rectangular type button exposed ..push this to reset position...you may have to push it a few times...then try vacuumniing.....I finally had suction from soleplate!! Another tipoff to this problem is my selector dial would not stay in place would pop I to carpet by itself, but only halfway....fro a long time my vac would work but not very well...had to go over same area.4-5 times..What a workout! The first time I contacted dyson via tele the rep had me remove some stuff and I was able to look at area below selector...what I saw was two holes, one hole was only over the other hole half way...hence at that time I had only part suction since holes were not aligning properly....I read somewhere as a further tip to get suction to engage, while vac is reclined step on front edge of vac head it said you'll get more suction that way, I haven't tried that, but thought it may help someone
    Feb 16, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Brush doesnt turn
    Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
    not gonna stay depressed, it's gonna pop right out - that's normal.
    - Step on the red pedal on the back
    - Turn the machine on with the red power button
    - Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
    - If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
    this link is for the manual..
    http://media.dyson.com/downloads/UK/floorcare/Manuals/DC24_allfloors_uk.pdf
    Sep 23, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
    Dyson DC41 brush won't spin
    You need to check the belt hooked to the side of the brush (sometimes hidden by plastic)
    Jun 26, 2012 | Dyson Bagless Upright Vacuum DC41 Animal
    Dyson DC08 turbo brush won't turn but have suction in tube
    Hi Cathy,
    I'm sorry to hear you're having difficulties with your DC08's turbo brush. As you've already checked the machine for blockages and washed the filter, I'd encourage you to get in touch with us directly so we can provide further assistance to help resolve this.
    You can call us on 0800 298 0298 - our UK Helpline is available from 7am until 10pm, 7 days a week. It will help if you have the machine to hand when you call.
    We'll look forward to hearing from you.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Feb 26, 2012 | Dyson DC08 Hepa Allergy Bagless Canister...
    Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
    Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Customer Service
    Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Brush wont turn belt not broken no sure how to get to shaft to see if it is turning
    Sorry to hear you're having difficulties with your DC07. If the brushbar in your cleaner doesn't seem to be rotating, please check you have the brush control set to 'Carpets', as it won't rotate when set to 'Hard floors', or if the cleaner is standing in the upright position.
    If the brush control is set correctly and the brushbar still won't turn, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Jul 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    My dyson is not sucking. There is no clog and the spinning brush on bottom is spinning.
    Even though the brush is spinning, you probably need to replace the belt because it is stretched. It is probably slipping on the beater bar. bbDo you ever smell rubber burning while vacuuming? If so, it is the belt.
    Jim
    Nov 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Beeter brush not spinning
    Hi If the Dyson has a brush protected switch on the left hand side of the machine, then it has a drive belt that can only be replaced by a serviceman or Dyson repairer. If the Dyson doesn't have brush protection, then pop open the sole plate and change the drive belt.
    Apr 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Vacuums Logo
    127 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
