Question about Whirlpool WED5520SQ Gas Dryer
It glows, ignites, and burns for 2-3 minutes, then it will only glow. I understand the valve are not opening to release gas in subsequent attempts. I have replaced the coils and the thermal fuse. The airflow is fine. I have continuity on both rear sensors and the sensor next to the ignitor. The blower seems to work fine and there are no obstructions. I dont know where to turn at this point.
  • 10,319 Answers
Is the exhaust vents clear? if not the heat will be in the check mode till thoroughly cleaned
Posted on Aug 02, 2010
Kenmore gas oven 326b1016p001
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 03, 2014 | Kenmore Ovens
Oven starts and stops
Apr 02, 2014 | Kenmore Ovens
No gas to oven
Mar 01, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ignitor work but burner do not lite
Feb 16, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Glow coil glows but wo'nt ignite burner. can
if you have used the self clean function you may have burned up the ignitor they are rated for about 1000 deg for just about a minute but when you clean it stays around 800-900 deg for about an hour or so. You may just need to replace the ceramic ignitor. as for the gas, the valve will only stay open for a few seconds, if the oven doesnt recognize a flame the gas valve will close.
Jul 26, 2009 | Maytag PER5710 Performa Electric Kitchen...
Bake burner flutters
[ the glow coil } the ignitor is call needs replacing it'snot getting hot enugh to open the safety valve.it's no more then $45.00. Berry common problem.
Dec 09, 2008 | GE Profile Spectra JGB920 Gas Kitchen...
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Whirlpool WED5520SQ Gas Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
