Question about Bialetti Brikka Espresso Machine
Need a copy of instruction manual for Bialetti Brikka model espresso maker We measure out the right amount of water with the plastic cup, but a lot of it runs out of the valve before coffee is made. We lost our manual so do not know what we are doing wrong.
    Sniper:
  • 66 Answers
Hey, screw the 2 parts tight and before that check if the filter plate is not clogged. See this guide that I wrote Avi
Posted on May 21, 2011
You just put the amount in the plastic cup, as long as it doesn't cover the safety valve that should be fine. Make sure your filter plate isn't clogged.
Posted on Oct 15, 2010
Missing measuring cup for Bialetti tuttopasta machine
Here are the measurements for basically every pasta maker:
Full Load
Liquid: 2 eggs and water to total 7 oz.
Flour: 3 1/2 cups flour with a small amount of olive oil (1 tsp?)
Half Load
Liquid: 1 egg and water to total 4 oz.
Flour: 1 3/4 cups flour with a small amount of olive oil (1/2 tsp?)
Dec 01, 2013 | Ronco Automatic Popeil Pasta Maker
Side valve is releasing pressure too early.brikka is 3 months old
check your filter plate to make sure it isn't clogged , that could make the safety valve do it's job and go off.
Sep 11, 2010 | Bialetti Brikka Espresso Machine
Lost the measuring cup! Does anyone know how much
There is a line inside the water compartment, look for the rectangles that go from the bottom up in the walls, there is a line above them... that is the level for gas stoves, for electric ones just put a little more.
Mar 15, 2010 | Bialetti Mukka Express
I need instructions for a Cuisinart Iced Cappuccino Maker
I have a PDF of the user manual if you want me to e-mail it to you. In the meantime, here is my Wiki Manual (BTW, pagan, the machine does make hot espresso or cappucino, but it doesn't froth per se like a regular espresso machine - it just heats the milk internally and dumps it into the espresso):
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
Feb 26, 2009 | Cuisinart ICAPP-4
NEED DIRECTIONS For Model ICAPP-4
I can answer just about any question you have on the unit - I wasn't able to find the manual online, but I would be more than happy to scan and e-mail you my copy of the original manual. In the meantime, here is my basic Wiki Manual:
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
-Tha Mp3 Doctor
Feb 25, 2009 | Cuisinart Coffee Makers & Espresso...
How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
Jan 06, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Good evening! I have received the  Kontessa  Vev Vigano  12 cup from my family  but I don't have an  instruction book with it..  is there a  place where I can download  some simple instructions as to how...
You could use any Bialetti or Vev Vigano instructions created for aluminum pots. I have a 6 cup Vev Vigano Kontessa Inox, but the instructions that came with it were standard. Remember to use correct measurement of water and coffee. Coffee grind should be espresso. I don't know about 12 cup, but assuming that it's double of the 6 cup size, I use 9 oz of water and 6 tablespoons of espresso grind. You could go to www.vev-vigano.com. Their customer service is pretty efficient. Even if you didn't buy your pot from them, they'll reply usually within 24 hours. Good luck.
Jan 02, 2009 | Vev Vigano Kontessa Oro 12-Cup Espresso...
Bialetti Brikka Espresso Machine Logo
1,155 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Frank Russell
Frank Russell
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
