Question about Philips Magnavox Learning Universal Remote
Please help need to know how to prgram my remote without the codes i tried code seach and channel up the channel changed but what button do i push after the channel changes. to save the code.
  • Anonymous Jun 12, 2008
    My TV stations are blocked with a black block.
It depends on brand. For Philips, press mute button to save code. The best website I found for all brands of remote codes and instructions is http://www.remotecodelist.com/remotes/
Posted on May 15, 2008
How to I program my remote to control VCR
First find out the setup codes for your device.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Oct 10, 2012 | Philips Universal Remote Model SRP4004
Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 19, 2008 | Televison & Video
HI MY FRIEND sreeki.
Try this site:
It's the manual for a Phillips remote control. The codes should be rather universal. Otherwise, there is a way to program it without using a code.
Hope this helps :)
Jun 14, 2008 | Philips Magnavox Learning Universal Remote
Code for Sony tv
Hope this helps :)
Jun 10, 2008 | Philips Universal PH301S Remote Control
Codes
Hope this helps :)
Jun 04, 2008 | Philips Universal PH301S Remote Control
Can you help me program my remote?
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Ilo dvd player/recorder
I think you are out of luck, unless you can find someone else who owns one, and will let you use their controller to program a learnable remote. I have purchased, and returned dozens of universal remotes...not one has worked.
Sep 23, 2006 | iLO DVD Recorder DVDR05
Philips Magnavox Learning Universal Remote Logo
88 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
