I've had this happen before,first make sure that the black burner cap is clean underneath and it's making good contact with the aluminium burner,also make sure the igniter is sparking across to the burner, check the ceramic coating around the igniter isn't cracked or the wires shorting out . Good luck.
The problem is the burners switch the the single burners has failed, this will cause is not to fire the module and ignite the burner. I would replace just that burner switch to correct the problem. When you call for parts, make sure you have the complete model number and possible color of that burner switch needed. They make or have available switch that are sold by color, so color may be needed for this model.
If none of the burners are working but the pilot light does you are having a power problem and only getting 120 volts to it. Check the breakers to make sure they are on correctly. 240 volts is needed to operate the cooktop. Hope this helps. Rick
The middle light is the lock. You must hold it down for at least 7 seconds to unlock it, then the middle light will go off. Your hands can't be wet, or none of the buttons on mine work right.
If indicator lights are all that wont work there is a "P" terminal on the surface switches (unless they are controled through a board). The P is for Pilot And 1 side usually the "P" terminal of the switch is allowing the light to recieve the power signal that the element is recieving from the switch. The other side of the pilot light(s) will all be wired together at a "common" pont.
My guess is that if you have individual piolet lights this common point is not tied in to the circut now. 1 wire off or loose and none of the lights work. However it should be simple to trace back to this point and effect repair to it.
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Hold your finger or thumb on the red light for a few seconds, and you will hear three beeps. This tells you that the lock is off. If the light is not on, do the same and there will be three beeps, and the light will come on, telling you that the lock is back on.
Hello
A similar think happened to my wall oven and after many frustrating attempts, I just unplugged the oven for about an hour and when Plugged back in it had reset itself.
Eddie Rentas
Tupper Lake NY
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
