SOURCE: Delivers only small amount of coffee per brewed cup
Same problem happened to me. There is a plastic boot inside the tank that is broken. This seals the top to the tank to the center rod. Keurig will not sell me the $5 part. They would would be glad to sell me a new brewer though!
SOURCE: keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
SOURCE: hot water does not go through the individual cup
check to see if the outlet hole is plugged up and use a tooth pik to clean it out then try bo brew again..
SOURCE: Coffee grounds in cup w/ Keurig 60
This is a problem with the k-cups themselves. Each K-cup has a coffee filter type media in the top and bottom of each k-cup. It sounds like you may have purchased a batch of k-cups with a defective bottom filter. Just to be sure, run your Keurig with no k-cup in it at all and see if it flushes clear hot water. Since your holder may have remaining grounds from the defective k-cups, you may have to do this several times. Once this is done, you can confirm it is working with another brand or batch of k-cups. The only way the brewer itself could be the cause is if the needle in the bottom of the k-cup holder has somehow become dislodged and is piercing the filter in addition to the k-cup bottom.
I hope this helps. Good luck!
SOURCE: when i put the coffee cup in the keurig....nothing
use a small needle, paper clip or pipe cleaner and run it up into the "needle" section under the lid that pierces the top of the cup. The problem is one you will have often as coffee grounds get up in there and dry between uses and clogs the hole.
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
';][-0
