Question about Canon Rebel XT / EOS 350D Digital Camera
Buttons unresponsive in manual mode
The ISO, WB or view images button is totally unresponsive when i am in manual, tv or P mode. basically i can view images if i change the mode to auto
  • 94 Answers
Opne camera and clean big flex which is connected to main pcb. try out if work then fine
other wise check finder unit connection is ok and clean out.
Posted on Aug 08, 2010
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Somehow my camera, a Nikon D60, is now displaying 4 smaller pictures on the monitor vs the full screen picture I just took. How can I change it back? I cannot find an answer in the instruction manual,...
You pushed the wrong button! On the left side of the LCD display, there are four buttons. One is labeled "ISO" and the other "QUAL". In the viewing mode, these buttons are used to allow you to scan multiple frames at one time. Each time you press the ISO button, it increases the number of images displayed. Each time you press the QUAL button it reduces the number of images displayed.
Oct 04, 2013 | Nikon D60 Digital Camera
Nikon d3 where is reset button
There actually are two buttons. Press and hold the ISO and WB buttons on the back of the camera (both marked with a green dot) together for more than two seconds. Full details are in the "Two-Button Reset: Restoring Default Settings" section of the manual (beginning on page 206 in my copy). If you need a manual, you may download a copy from here.
Jan 24, 2013 | Nikon D3 Digital Camera
D700 wb/iso/qual buttons not working
You could try to do a full reset of the camera from the menu, but I don't think that will work. Since your camera is less than a year old, it is still under Nikon's warranty. Call 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They can advise you and provide warranty service if necessary.
Sep 15, 2012 | Nikon D7000 Digital Camera
How do I turn on the Rear Command Dial in my Nikon D80 Digital Camera?
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode.
If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Jun 29, 2011 | Cameras
Hi, I have a Canon T2i Rebel. When i put the camera in "M" (totally manual), the image doesnt appear in the LCD screen. Everything else works fine in the monitor, but it is as if the lens where...
That's great news, so let's write it up as a solution so that other people who search on here find the right information!
So it appears that the Canon T2i when in manual mode (M) remembers whatever settings you play with, and that these settings are remembered across power cycles; in other words, turning the camera off, or switching to auto before going back to manual does NOT put the settings back to a default.
This gives you the opportunity to set choices that make the screen view totally white or totally black, and unless you realise what you did, you can fear that your camera is broken in some way. At first, I thought this was a user interface flaw, but at least with the screen black or white, you know which way you need to go to get your picture back! The settings that affect brightness are Shutter Speed, Aperture Value, and ISO Rating. They are accessed in manual mode with the thumbwheel, alone, with Av, and after pressing the ISO button, respectively.
One more little bit of trivia: when in manual mode if you don't have live view on, when you half press the shutter, a little indicator comes up on the exposure scale, so that you can see how the settings you've chosen are going to come out.
P.S. I noticed that there was a forum especially for your camera, you might like to join it, it's called t2iforum dot com.
Jan 24, 2011 | Canon EOS 550D Rebel T2i Digital Camera
ISO stays on Auto. I push the ISO button to change the ISO off of Auto and it doesn't do anything on my 40D
The ISO is set to Auto and can't be changed when shooting in Basic Modes (all of the icons and the green circle). ISO can only be adjusted in Creative Modes (P, Av, Tv, A-DEP, M). If you want to adjust the ISO in Creative Mode, press the ISO button and then turn the dial next to the shutter trigger.
Apr 06, 2010 | Canon EOS 40D Digital Camera
I can't view advanced options. The date stamp on/off button has vanished. My Polaroid i634 has been restored to original settings, and now iconc/buttons are no longer there. How do I turn the date stamp...
I turned it on, and pressed the video/live recording button that was next to the trash/delete button. That is a whole other menu. After pressing the video/live recording button, I just went up to the first selection, "Program." That takes it off the basic/Q-Mode, which opens additonal options, like ISO and Date Stamp on/off. So basically:
1) Turn on, having the camera on picture taking mode, not review picture mode.
2) Press Video/Live Recording button.
3) Go to first option, called "Program"
4) In this mode, many other options are available, and there will be smaller icons.
Jan 02, 2010 | Polaroid i634 Digital Camera
I have a Canon Rebel XT/EOS 350D. For some reason when I try to view the AF, ISO or WB menus they are not displaying. Can you help?
You need to set your Mode Dial to one of the modes in the creative zone (i.e. one of the modes: P, Tv, Av, M or A-DEP) in order to access the AF, ISO and WB menus. Those menus are not displayed when the Mode Dial is set to one of the Basic Zone modes.
Hope this helps /Chris
Jan 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Can't change iso setting using iso button
If your camera is on auto, you must turn the knob on the top to manual.
Nov 01, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
