Question about LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium
Not making ice. Please help - LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium
    President:
  • 1,099 Answers
ICEMAKERS OFTEN STOP DUE TO A WARMER THAN USUAL FREEZER TEMPERATURE. MEASURE THE TEMP AND IF IT IS UNDER 10 DEGREES F. IT SHOULD BE DUMPING ICE. (IT WOULD HAVE FASTER PRODUCTION IF SET TO O DEGREES.) IF IT HAS A "NO WATER" PROBLEM YOU WILL HEAR IT HUM FROM TIME TO TIME AS IT CYCLES BUT DOESN'T DUMP ICE. THE EASY WAY TO CHECK FOR A 'NO WATER' PROBLEM IS TO TIE A 10 INCH OR SO PIECE OF LIGHT TWINE ONTO THE SHAFT AND CHECK IN A FEW HOURS TO SEE IF THE SHAFT IS WINDING THE TWINE UP ONE TURN PER CYCLE. IF TEMP IS COLD ENOUGH AND IT IS CYCLING THEN THERE IS NO WATER GETTING TO THE ICEMAKER. POUR A CHARGE OF WATER IN THE TRAY/MOLD AND IT MAKES ICE AND DUMPS ONLY THE ONE LOAD IS ANOTHER WAY OF CHECKING. THE NEXT MOST LIKELY PROBLEMS MIGHT BE A WATER LINE FROZEN DUE TO A SUPER COLD FREEZER OR A BAD SOLENOID VALVE. I HAVE NOT SEEN IT BUT I WOULD CHECK THE WATER FILTER ALSO. IF THIS DOES NOT SOLVE THE PROBLEM-YOU NEED TO GET THE MODEL NO. AND SERIAL NO. OFF OF THE NAMEPLATE. I BELIEVE YOU HAVE TAKEN IT FROM THE BOOKLET AND YOU ARE SHORT SOME DIGITS.
HOPE THIS HELPOUT AND GOOD LUCK......
Posted on Aug 02, 2010
Everstar HDIM 35 ice maker
Click below ;
There's no ice
Hope this may help
Jul 30, 2008 | Freezers
Ice maker isn't making ice, and the switch is on?
Hello, Thank You for using FixYa. I will be helping you today.Check to make sure there is no ice cube stuck in the ice maker.Also check to make sure the fill tube coming through the back wall is not frozen.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Maytag Refrigerators
Ice maker stopped making ice. I emptied ice holding tray and since then, if will not make ice. I adjusted arm in hole correctly. Arm is down and is in correct position to make ice. Still no ice. Please...
Fill the ice maker with water. If it freezes and dumps the the water control valve on rear of the refrigerator and near floor is defective and will need replace. If the water just freezes then the ice maker thermostat is the problem, Let me know,Thanks Sea Breeze
Aug 17, 2009 | Refrigerators
Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice.  Check it tomorrow.
May 31, 2009 | Jenn-Air JCD2295HES Side by Side...
THE ICE MAKER WILL NOW ONLY MAKE A FEW CUBS
Our Kenmore ice maker GSI23 has stopped making ice cubes, the water still flows out the front, the sensor arm is down and we have pushed on the O button numerous times but still no ice. Help please
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker
Hello Carol34,
I'd like to help you but you will first have to provide some additonal information. First off, did it ever work? Not sure what you mean when you refer to the 'part that goes down to release ice just stays down".. are you referring to the arm that shuts off ice making when the bucket is full? Please provide this information so that we can get your ice working again..
Thanks
Aug 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker
Hollow ice is a sign that the icemaker is not getting enough water.
You will want to make sure there is enough water coming to the fridge and any filters in the system are clean.
If you need help checking it, please post the complete model number from the fridge and I can help you more.
Nov 24, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Ice maker not making is
What kind of controls does your ice maker use to make and shutoff the water. Does it use electronics or mechanical arm that raises to shut off the water?.
Nov 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium Logo
79 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
