What does EE mean on the screen of the window air conditioner unit?
SOURCE: Maytag error message EE
What is the name and model number of your unit?
Posted on Jun 20, 2008
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
  • 3 Answers
SOURCE: EE problem
It could be the control board. I found out that this model air conditoner has had problems with moisture getting in the control panel and shorting it out when it's humid outside. I have the part number if anyone wants it. It cost me about $45 from Sears Parts.
Posted on Jul 08, 2008
SOURCE: I have a Maytag A/C
Why should I tell you how I fixed the problem for free if you can't even tell me how to solve this problem for free. I just wanted to know what the error code meant and if it can be fixed or is the unit junk.
Posted on Jul 29, 2008
koolbreezes
  • 540 Answers
SOURCE: window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Posted on Sep 02, 2008
Te 522 error EE
EE stands for Energy Efficient. The problem could be:
1) a bad thermostat 2) inadequate ventilation (blockage) 3) a bad controller board if the unit does not come on following this display.
The manufacturer pretty much decides what these specific codes mean. You might have to contact them.
Apr 07, 2015 | Heating & Cooling
Repair of room air conditioner /window unit
You need to check the main breakers in the breaker panel......
Sep 01, 2008 | Heating & Cooling
Displaying "EE" Code. Does not run.
the best suggestion is to contact the manufacturer at: (877)337-3639.
Jun 19, 2014 | Haier CPN10XCJ Air Conditioner
Flashing EE:EE on airconditioner wall control
your system might need reseting look for a reset switch on your thermostat or your inside unit usually means dirty filter
Jan 04, 2013 | Heating & Cooling
Error code [e r]for whirl pool air conditioner. How to reset air conditioner?
Whirlpool window AC with code EE What does that mean? Model # is ACSP82PPO AND how can we fix it?
Oct 29, 2011 | Whirlpool ACQ128 Air Conditioner
Shows ee and will not come on
EE is an error code. I cant help you with this one , but it means something has failed. Try the Fedders site or a Fedders Agent who may be able to state what the EE code means and then see if you can purchase or obtain a Tech to fit the part required.
Jul 03, 2011 | Fedders AEQ07FBG Air Conditioner
My air conditioner turned itself off and now the display reads EE we have unplugged it it runs for a little while then shuts itself off again
Remove the unit from the window,and dissassemble and use a water hose and clean the inside of the unit,remove all debris,this is most likely the problem.
Jul 10, 2010 | Maytag M7Y15F2A Air Conditioner
Error code EE on a panasonic window unit
EE- High pressure problem. Clean condenser coil and check amps. If gradually high replace capacitor.
Aug 23, 2009 | Panasonic CW-XC104HU Air Conditioner
EE in the display window
Hi, I have been trying to get in touch with a service rep to find out but unable to get one. They wanted proof that I had purchased a unit. Its possible that your receptacle is not polarized right. By that I mean the two wires may need switched on the receptacle or maybe it doesn't have a good ground. You may want to try temporarily using an extension cord and try another plug. Most things will run good on receptacles wired wrong but with a computerized AC it may be seeing a fault. If you still need help I think the best way to find out would be for you too contact the store that you bought the unit from and make it their responsibility to find out what the EE stands for. If they cant, get the unit replaced and try again. If you do get hold of a service tech # from Maytag, please send it to me at kstfas@yahoo.com Hope this helps. kstfas
Aug 27, 2007 | Maytag M7Y10F2A Air Conditioner
Air Conditioner won't work after resetting and testing
What kind of a.c. and what is the model number
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 18, 2017 | Fedders A6X08F2BCOM Thru-Wall/Window Air...
Heating & Cooling Logo
274 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
