Question about Xerox Phaser 8500/8550 All-In-One Thermal Printer
Phaser 8500 - cannot print color under 64-bit Win 7
I recently converted from 32-bit Vista to 64-bit Win 7 with a clean install. Win 7 recognized my Phaser 8500N PS, but I cannot print in color.
Went to Xerox website and downloaded recommended driver for 64-bit Win 7. It was version 5.48.30 and had a date of 10/29/07 - seems pretty old to me. I uninstalled the MS driver and ran the Xerox driver in Vista SP2 compatibility mode. It could not find the printer in IP mode (its connected with a USB cable) and failed to install.
So I'm stuck with the MS driver and can't print in color. Any suggestions would be greatly appreciated. Thanks.
- Phil -
  • 700 Answers
To start from the beginning, i understand that you are running win7/64bit, usb connected. on base of this assumption we will try to solve your problem. by the way, i love this printer!
1. disconnect printer from usb port,
2. remove all instances of your printer and printer driver from your computer, run ccleaner to clean the junk including registry
3. download again your printer driver (it should be about 6.3mb, lite version which you most probably downloaded will not work!), just in case if previous download was corrupted, choose global english as a lingo.
4. http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=8500_8550&ripId=&Xtype=download
5. unzip file to root directory or desktop, anywhere where you can find them easy.
6. connect your printer to the computer
7. right mouse click on "my computer"
8. left mouse click on "control panel home"
9. under "hardware and sound" left click on "view devices and printers", your printer should be there
10. 2x left click on the printer
11. 2x left click on "customize your printer"
12. left click on "advanced" tab
13 select "new driver"
14. select "have disk" and point search where you did unfold the drivers.
as this particular printer is part of build in microsoft printers, often microsoft is overriding your preferences and this process will allow you to use manufacturers settings not a microsoft.
after this your printer should be visible in printer folder as default. make test print,
if you find this solution useful, please do not hesitate to leave feedback and vote4 for me, if you do require additional help, please call back.
Posted on Aug 02, 2010
  • aamirjadoon Nov 12, 2010
    Hi, I just want to add some thing more as i was also facing a same problem on windows 7 x64.
    The driver name is "PSCRIPT5.DLL"
    and the driver download file name is "X-GPDWin_PS_x64.exe" 25.6 MB
    It may not install itself if you just extract and install it by double click.
    You may need to follow the above procedure by selecting the driver on extracted path (Default:C:\Xerox\X-GPD_PS_x64Driver )
    same for 32 bit version of driver.
    Aamir
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
I DON'T HAVE DRIVER OF EPSON STYLUS C59 FOR WINDOWS 7
1. Follow this web address : http://www.epson.com.ph/epson_philippines/support/eol_product.page?support_name=Epson_Stylus_C59#
2. Hit drivers button
3. Select the Operating system Vista if you have Win 7 - 32 bit or Vista 64 if you have Win 7 - 64 bit
( You can find out what win 7 version you have if you hit right click on My computer > Proprieties )
4. Download driver and install
5. do not worry, Vista drivers will work under Win 7
Feb 19, 2011 | Computers & Internet
I have the photo printer for 4 years, just installed it with original ink cartridges, the printer prints regular text just fine, but in trying to print photos, the photos come out very red with no...
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 28, 2010 | HP Photosmart 8450 InkJet Printer
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
It is taking about 30 minutes, no joke, to print one page. There are long delays and then it seems to do a line and then another delay. This just started today which is a surprise as the printer has been...
Try HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP DeskJet F380 All-In-One Printer
Black lines on scans and prints HP 2727nf
Oct 27, 2010 | HP Laserjet M2727nf Multifunction Printer
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
Apr 08, 2010 | Dell Precision Workstation 490 - MT -...
D-link DU-562m does not work with windows 7 RC Ultimate 64 bits
Download from the following site.
http://load2.file-drivers.com/download.php?id=87889
Jun 09, 2009 | D-Link DU-562M Modem
Xerox 8500 will not recognize paper size
Hi Don,
Looks like you need to download the driver for 64 bit windows, I believe there have been some issues with 64 but hopefully this will help!
Try installing this driver - Windows PostScript PPD Driver Files - 32/64-bit
Use this link for any further problems with you 8500 -
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_8500_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_8500_8550):str(8500_8550),question=ref(ProdFamily):str(Prod_8500_8550),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:8500_8550,varset=prodName:Phaser%208500/8550
Feb 24, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500/8550 All-In-One Thermal Printer Logo
910 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
