Question about HP Compaq Presario V2000 Notebook
My compaq laptop shuts down All power connected and battery shows good. It runs for 3-5 minutes and then shuts down.. Almost like overheating or something like that and something shuts it down.
    Scholar:
  • 72 Answers
It sounds to me like it is indeed overheating. Make sure all the fans visible from the outside of the case are operating smoothly, and not making any awkward noises. You can take a flashlight to see these easier. With the laptop off, make sure you have any dust cleared out, you an buy an air can for about $5 almost anywhere that sells electronics. Another easy solution for anyone to do, is buy a cooling pad. It will increase the airflow to the computer, and keep most of the case's openings clear.
If you are still having problems, make sure you have any peripheral devices disconnected, as there may be something drawing too much power from the notebook.
Posted on Aug 02, 2010
How do you stop a laptop from shutting down?
When the overheating issue is fixed, the laptop will reset. Did you clean the radiator? Is the fan running?
Oct 09, 2014 | Computers & Internet
My computer shut off out of nowhere with no warning.
They are a problem when they overheat. No warning just off. Try cleaning the fan and radiator. You will have a fighting chance then.
Mar 09, 2014 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
I have a HP laptop that will run for about 15-30 minutes, then it will suddenly shut down. It isnt overheating (hovers around 60C) and its not the OS or Ram. This occurs both on battery and AC power. Any...
This could be a motherboard issue. Make sure the screen isn't just shutting off after 15-30 minutes. If you hear no fans or anything else running, I would say do a laptop craft project. They are very enjoyable!
Mar 03, 2011 | HP Compaq Presario V2000 Notebook
Compaq Presario F572us will not stay powered up. It starts and then screen goes black and shuts down. When I press the power button again it lights up but the computer powers off again.
Here's what you can try.
1. Remove the battery and try turning the laptop just from AC adapter. Maybe the battery is bad and shorting the system.
2. Try turning it on just on battery power (with AC adapter removed). Maybe the AC adapter is bad and shorting the system.
3. Try removing memory modules one by one. Maybe your failure somehow related to memory. Test the laptop with only one memory module installed. Try either one.
If nothing helps, the laptop still turns on and off by itself, most likely this is motherboard related failure.
Jan 19, 2011 | Compaq Presario F572US Notebook PC
I have a Compaq NW9440 Mobile Workstation - it keeps shutting down every 15 minutes or so. At times, it will not restart right away. I thought it may have been the CMOS Battery, so I replaced it. It's...
The most common problem you get with a laptop is overheating, this can cause for it to shut down while operating to prevent more damage.
You will know if your laptop is overheating if it happens one ore more of the following:
-The keyboard and the bottom of your laptop are very hot when the laptop is working.
-The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
-The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
-The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Follow this steps to avoid overheating:
-Don't use your laptop in full sunlight for extended periods
-Don't leave the laptop in a closed car on a sunny day
-Don't place the laptop on or near extreme heat sources, such as radiators, hot air vents
-Turn off your laptop before putting it in your carry bag
-Turn off your laptop when not in use for a long period
-Work on an even surface as much as possible, not on your lap!
-Clean the air vents in your laptop regularly by using a can of compressed air
-Get more space under your computer by propping it up on something when it's on a desk
-Consider purchasing a laptop cooling pad
-Consider purchasing an external fan
To clean your laptop's cooling system:
-Shut down the laptop ie do not leave it suspended, sleeping or hibernating.
-Unplug all cables from the unit and remove the battery pack
-Get a can of compressed air and blow it into all vents around your computer - this should clear out any dust and hair.
-Do Not use a vacuum cleaner.
If it is not overheating, then it is a hardware failure. Could be the RAM memory, or the motherboard. You can only corner the problem by testing with different RAM modules or motherboard.
Dec 01, 2010 | HP Compaq nw9440 Notebook
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
Battery and/or overheating or ?
It is possible that the battery is not charging at all and can't pass electricity to the board. But if its 3yo, its probably really dead.
Also, if you can see a fan not working at all, overheating is also possible.
It is also possible that there is a tiny foreign object capable of conducting electricity, such as human hair, that gets activated at the slightest movement of the laptop by shorting some pins on your board.
So I would suggest to observe more or clean the inside of your laptop if you know how to remove your keyboard.
Apr 28, 2009 | Computers & Internet
I have a Compaq T2200XR UPS, the battery is out, it shows a battery with and X, my question is, Is it going to shut down or it will keep passing truw power with no battery until I get a new one in 2 or 3...
Wait till you get the new batteries........, then swapped them out.
The answer is yes, until you have a blackout. oops.
You have something..... so
By the way give me the battery information and I will send you batteries. Be happy to sell them to you. I may quote yoiu a better price then anywhere else.
Call me 727-823-6100
Good luck.
Dec 03, 2007 | Compaq UPS T2200 XR UPS System
Power failure
Hi Asadi Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps. Regards Harry
Jun 14, 2007 | Compaq Armada M700 Notebook
HP Compaq Presario V2000 Notebook Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
