My LG HDTV keeps shuting off its not a plasma, we cleaned out the air vents and still it shuts off. It's connected to AT&T unvirse cable box and a pionner home theater system
  • 10,594 Answers
I need to know model number of your LG tv to diagnose possible cause of problem.
Model number would be written on sticker pasted at back of tv.
Thanks.
Posted on Aug 02, 2010
  • dcrowley1983 Aug 02, 2010
    a05amdz113146
  • Shahid Electronics
    Shahid Electronics Aug 02, 2010
    This is not valid model number of any LG tv, please recheck.
I have a 50" LG plasma that turns off after a couple of minutes.
check the solder side of the pc board. If there are any connections that look grey (as opposed to shiny) you need to re-solder them.
Dec 12, 2014 | LG 50PC5DC 50 in. Plasma HDTV
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Oct 19, 2014 | LG 55LK530 55 inch 1080p LCD HDTV, with...
Can I connect my teac AG 100 amp to my LG plasma tv?
yes.....connect to digital audio output.........optical fiber optic cable needed.....connect to digital audio input on hi-fi.......select pcm as format............good success, meder's tv service
Oct 14, 2012 | LG 50PK550 50 HDTV Plasma TV
LG Plasma TV Buzzez when HDMI cable is connected, not all the time just randomly. different stations different times, why
HDMI is very prone to audio problems--the advantages of HDMI are just one cable combines all---Issue if using a box or only on certain channels could be coming from the box if used.
If using component connections and no problem at all-it likely is not the set.
HDMI sets sometimes require a software/firmware update to resolve issues here--if random it is going to be hard to resolve.
Apr 16, 2012 | LG 50PC5DC 50 in. Plasma HDTV
The dryer keeps shuting off and saying check filter
Check the rear exhaust vent at the bottom back of the dryer. If it is clogged it can cause the dryer to "overheat", that is ... if the vent is clogged with lint and debris a fire could start if there was enough heat.
Please rate this answer for me. Thank you
Mar 26, 2010 | LG DLE5977 Electric Dryer
I am trying to connect my lg 50'' plasma trying to my lenovo through vga to hdmi cable ,but am not geting display on lcd.
from a cable box you must have the box in hdmi mode turn cable box off with tv on and press menu on cable box remotly scroll down and turn on HDMI
Nov 18, 2009 | LG 50PX5D 50 in. Plasma HDTV
Can i connect with hdmi cable
If tv has hdmi input you can otherwise component aav input is the best,
Jul 08, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Keeps shuting off
If the receiver shuts down after some time operating properly it is likely caused by a heat issue or crossed (shorted) speaker wires. Please make sure that the unit is adequately vented and the air vents/fan on the back of the receiver is clean. If it is then carefully check all of the speaker wires for cracks, damage, and/or crossed wires.
Feb 26, 2009 | Yamaha HTR-5630 Receiver
Lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Apr 29, 2008 | LG 42PX5D 42 in. Plasma HDTV
Plasma
if your tv is on warranty take it back to best buy for a replacement.good luck
Apr 27, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
