Question about Vizio VP322 32 in. Plasma TV
Tv won't power on
I have had this tv for one year and 13 days. tv will not power on. vizio light turns white then orange. does any one know what the problem is. is it the power board?
  • 4 Answers
Could be the power board or the main board. You will know because its the capacitors that are most likely the cause. Vizio used the cheapest capacitor maker CAPXON, but to me its CRAPXON. The capacitors will have bulges on the top, and in some situations you will see they cracked open on the top. The capacitor degrades, creates hydrogen gas that escapes thru the top of the caps, which is good because it would explode if the hydrogen gas can't escape.
Cheapest solution is replace the bad caps with Japan or USA caps. They go for 50 cents a piece at electronics suppliers. Don't buy a used board because they too will have these bad caps and you will end up with the same problem down the road.
I learned my lesson, I fixed mine but I replaced only the bulge top caps, but there were about 60 more caps in my TV and they were all **** XON. Next time I am saving up to buy a SONY.
Posted on Aug 13, 2010
Vizio sv41xvt flashing logo. won't power up
Sounds like either a power circuit board or mainboard failure. I'm going through same problems, mine is power board failure.
Jan 11, 2013 | Vizio SV471XVT 47 in. LCD TV
My Vizio VX37L HDTV won't turn on. Was watching it one day & it turned off by itself. Replaced power supply with new one with no luck. Orange light comes on but will not turn white.
reset the tv with the tv off, but plugged in hold down the soarce botton on the tv for 5 seconds it should click on and work. if not then there may be curcuit board issues. i found the same tv on the side of the road as somewone was throwing it out, it was leaning aganst their trash can. i brought it home. plugged it in and it went on and inediatly went to the orange vizio light. i rest it and it's been perfect ever since is my comoute monitor now...good luck i hope that fixes it for you..
Nov 25, 2012 | Vizio L37 Television
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Jun 25, 2009 | Vizio VO47L 47 in. LCD TV
Orange light will not stay on when the tv is off.
replace the power cord, do not use tv till you replace the power cord ok, you will eventually short circuit the tv or even worse blow the internal components
Jun 22, 2009 | Vizio L32 32 in. LCD HDTV
No picture but sound
do any lights come on with the TV?, like white vizio or orange vizio light. sounds like a problem with the power board. some vizio parts have lifetime warranties so contact vizio support and report your problem. if it is covered the service call is free. there is a green led light on the power board that should come on, if it is not on, you may have a bad power board. to see this light on the power board, turn off the lights in the room and view the tv from the back cover, power board is 3/4 way toward top in the middle of the tv
Mar 26, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Vizio VP322 32 in. Plasma TV Logo
191 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
