Question about Sharp Televison & Video
Sharp tv model vt3428x program timer
HI I have an old Sharp vt3428x without a remote.
It has a program timer that comes on after a reset. I can;t use the video input until this is cleared.
How can I clear it without a remote.
Please help
Thanks.
MikeNJ1964
  • 398 Answers
SOURCE: program timer light blinking
The timer light blinks when the AC power has been disconnected and the clock is not set. This is how the set warns you that it can no longer do timer recordings. Setting the clock and doing an autoprogram will fix it, but both the remote and the remote receiver must be working. If the original remote is not damaged and has good batteries in it but does not work on that set and you cannot get any other universal remote to work, then the remote receiver (the IR "eye") inside the set has failed and needs to be replaced. I have seen many of those little receivers failing recently. If you do not have experience changing electronic parts on small PC boards then have a qualified tech change it for you.
Posted on Jul 26, 2007
SOURCE: Tv Combo will not work with replacement remote
my panasonic tv model no. PV-DF2704, program light is blinking and I don't know how to cut it off. It is causing my tv to cut off. My remote control will not work. I bought it second hand. I program a universal remote and it works for a little while, but I can not set my tv for cable. Please help me if you can.
deborah from Louisville
Posted on Feb 26, 2008
SOURCE: Programming the Acquos Remote
Input code 0093 into your Comcast remote. Here's a link for the how to: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
Posted on Mar 01, 2009
dsacco86
  • 1077 Answers
SOURCE: need help programing a directv remote to a sharp tv, model # lc46sb54u
I know what you mean. :(
I couldn't get mine to work with my Emerson TV. No codes worked.
You may have a chance with yours. Try this link here to get and program the codes:
http://www.directv.com/DTVAPP/global/contentPage.jsp?assetId=P4350020#
Then if does control the TV, hopefully the input button on the remote will work.
Posted on May 12, 2009
SOURCE: My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
Posted on Jun 22, 2010
Universal remote control sharp ga317sa because I loss the program manual and I need to reprogram it.
Most Sharp universal remotes came with a specific device (TV, DVD player, etc.). The directions for programming the remote will be in the manual for that device. The Sharp GA317SA came with several TV models. The GA317SA is the same as the GA219SA that comes with the 27F640, except for the light feature. Manuals Lib has the manual for this TV here: https://www.manualslib.com/manual/318446/Sharp-27f640.html .
The details on setting up the remote to use it with other electronic devices is on page 45, https://www.manualslib.com/manual/318446/Sharp-27f640.html?page=45#manual . This remote only controls the Sharp TV and a DVD player or cable converter box.
I hope this helps.
Nov 24, 2017 | Sharp Televison & Video
How do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
Nov 14, 2009 | Sharp 27J-S100 TV
I have an old Sharp TV connnected to Cox Cable. I have an RMT-V303 Sony Remote. Can I program it to control the Sharp TV?
No,must have the same brand and somtime same models too.Tries a univeral remote,but u said this an pretty old tv.Tries this website 1-800-Remotes Factory Original.U can buy an exact or very close to the original remotes.
Sep 16, 2009 | Televison & Video
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Jul 09, 2009 | RCA Universal Remote Control
Need a new remote
A Phillips universal remote will work. Just program it for the TV Model. These are about $15 at Radio Shack.
Mar 01, 2009 | Sharp 27J-S100 TV
One for all remote for Sharp tv
You can go to teh link below. Select your model number from the list. Select the type of device in your case TV then select Sharp then click submit. That will give you your code. You will then see a link for manual. there you can get the insructions for using the codes.
http://www.oneforall-na.com/advanced_search.php
Nov 30, 2008 | One For All URC-3021 Remote Control
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
Jan 01, 2008 | One For All URC-3021 Remote Control
Televison & Video Logo
32 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
