Question about Garden
I need the instruction manual for the gardena T14 model auto sprinker. it's about 7 years old and the instructions for setting the times etc., have been lost. would greatly appreciate any help out there. thank you very much. ed
Hi, I found an user manual in french..(but with pictures..:-).
This is the link. Before downloading u have to vote the product giving the stars.http://diplodocs.it/314159.php?k=f8d001f8a3e78dc7e505635db5c4a464&ID=2232246&q=GARDENA%20T%2014
By and good luck
Posted on Aug 05, 2010
My gardena water timer won't stop bipping. See the picture. Is it the battery ?
for the Gardena-T-1030-1805 model....
Gardena 1030 1805 Operating Instructions Manual Page 7
11. Battery
11.1 Status indicator
If the battery capacity falls below a certain level, a warning signal sounds every 15 seconds. The programs you have set are not run. The water flow cannot be opened manually. If a valve is open, however, it will be closed.
11.2 Changing the battery
If the battery capacity is too low (the warning signal beeps every 15 seconds), you must change the battery.
To do this, the water timer must be removed from the tap.
Important : Changing the battery deletes the data you have set.
To change the battery :
1. Insert the battery in the battery compartment
2. Set the Run Time control knob
3. Reset the watering data as described in "Setting the watering data".
3 If the Run Time knob is not turned to Reset, 5 seconds after the
battery was inserted the current Run Time shall be accepted. This is confirmed by a double beep.
Note : The time the battery was changed is taken to be the starting time.
To ensure that the water timer works properly we recommend that you insert a new battery at the beginning of every gardening season, or at the latest after a year.
Important ! Please dispose of used batteries properly at the appropriate communal waste disposal site. Only dispose of batteries when flat.
May 28, 2016 | GARDENA Hardware & Accessories
Gardena c14e water timer
You can find a T14e manual at this address if you still need one after all these years.. It appears to be almost identical to a C14e manual. Garden Water Timer Electronic Operating Instructions ManualsOnline com
Nov 28, 2012 | GARDENA Hardware & Accessories
Gardena t14 manual swich button is stuck . Cannot program timer
There is no magic cure for plastic, battery-operated, digital, water timers that are exposed to weather.
Try spraying WD40 on the button.
Turn timer upside down and spray WD40 again so debris can work it's way out of timer button.
Keep a cover over timer, do not expose to direct hot sun, and do not expose to freezing water or inner plastic valves will break.
Buy another timer.
Copy following link for Gardena manuals:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
Copy following link for various other water timers, Toro, Orbit, Melnor, Raindrip etc in no particular order.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 30, 2012 | GARDENA Water Timer
How to set specific dates to water with my T1030D? I don't need daily frequency for cool weather time. There is fequency dates to chooce on T1030, but not with T1030D.
1) Sept 2011.
If you have a T1030D timer instruction manual, then that would be helpful for many people.
Scan manual into .jpg format (file format) and then post images on Flickr.
Add a comment with link to those images so expert can access the information.
2) Currently the only instruction manual is the following, where you can also send information saying what your instruction manual says:
http://waterheatertimer.org/pdf/Instructions-for-setting-Gardena-T1030D.pdf
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
3) That being said:
Let me add some guessing, and then you can add a comment with what you observe.
Between us we might be able to work out a solution.
4) I don't think you can set specific dates on either T1030 or T1030D
It appears the T1030D is a weekly timer, just like T1030.
The word 'date' does not appear in T1030 manual except 'date of purchase.'
http://waterheatertimer.org/pdf/Gardena-1030-MANUAL.pdf
5) T1030D: each day of the 7-day week is broken into hour 1 through 24.
Each day can have between 1 to 3 settings. I think this is frequency.
You can set the watering run-time from 1 to 120 minutes for each set time.
Sep 01, 2011 | GARDENA Water Timer
Need manual for gardena model T 1030 D i can only find T 1030 without D...!
I cannot find T1030D manual posted anywhere, Aug 2011.
The Gardena site does not return emails or post manuals.
You can try the following 'possible instructions' and then add a comment saying what you discover.
Aug 13, 2011 | GARDENA Water Timer
I bought a Gardena 8135 Watering sprinkler but there are no instructions... It seems to do 360 degrees, but won't do a part circle - it goes one way and then gets stuck there...what am I doing wrong?
Dear Specialkfras, The same thing happened with our Gardena Sprinkler. It means the little clip at the bottom is faulty and you just have to return it to the manufacturer and get a new one. You are not doing anything wrong and there is no instruction manual in any of the boxes. Good luck.
Nina
May 25, 2010 | Garden
Need manual for t14 gardena water timer 12 yrs old approx
Program Cycle Duration (minutes)
man On Once 30
1 4 times a day 3
2 Twice a day 3
3 15
4 Once a day 3
5 5
6 30
7 60
8 Every 2 days 5
9 30
10 60
11 Every 3 days 30
12 60
13 Every 7 days 60
14 120
Can't believe I saw this...don't usually go on the hunt on the net, but wanted to see if I could source some more of these. I, too, have had my timers for 12 years and swear by them...Excellent product...just happened to go out to the shed today and found the last surviving box, with instructions !!! Good luck, Fiona
Jan 16, 2009 | Hardware & Accessories
Garden Logo
180 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
