2007 Hyunda Sonata air conditioner is blowing hot air. We checked all of the fuses and it didn't make a difference. Checked refriderant level and it is reading too high. Auto store said if the compressor it not on it will read too high. Compressor will not kick on but there was no noise or anything indicating that the compressor went out. Help!! It is too hot for this!
  • Heating & Co... Master
  • 17,448 Answers
Too high? what was it and how did you measure it?
Posted on Sep 12, 2017
vanni7
  • 163 Answers
SOURCE: AIR CONDITIONER COMPRESSOR WILL NOT KICK ON
Hi!!! if you have a run capacitor change it..If it still dont work then you have a bad compressor..good luck.
Posted on Jan 20, 2009
  • 30 Answers
SOURCE: Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Posted on Feb 01, 2009
  • 306 Answers
SOURCE: Compressor Fan stop working
Do you have a meter? Either the fan is bad or the capacitor is bad. Ohm out the fan and then the capacitor. Be sure you take the disconnect out of the electrical box on the side of the house and or trip the breaker off. The capacitor is a dual run one side operates the compressor and one side operates the fan. I would really bet on the capacitor being bad. Have seen that a lot in my experience. Be sure to make note of the wiring of the capacitor before you take it out to check and if you are not sure how to check it take it to the parts house and they can check it.
Posted on May 17, 2009
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
SOURCE: duo therm air conditioner that the compressor will not start
your switch should be oopen but when it reaches 41 degrees it should open so the system shuts off before it damages the compresor by sludging it, i have the same unit and my compresor runs for 5 seconds and shuts off, i checked the amp draw at the compresor and it draws 21 22 amps trying to start after the initial 5 second run, but it wont come on againts a load so the comprresos equilizes and tries to start over again with out positive results. i bipass the external obverload on top of compresor terminals area, still no fix yet, the relay on the control board continious to send power to the compresor and still draws , so if there is a problem with the control relay i would open up and dont send power to the compresor so i dont think is the relay, i am a a/c service man for
35 years and do this for a living still today, by experience i think it is the compresor gone bad but will try by passing the relay just to see what happens, also it could be bad capacitor since it have a hard start relay and start capacitor (black )also a run (silver ) capacitor they check ok, there is no way to check the charge unles you install a saddle tap to check presures and rechage this unit i think the compresor replacement is the way to go ( around 250) plus labor and freon r22 e mail add aljpuig@yahoo.com.
Posted on May 06, 2010
Air conditioner blows heat, conditioner was charged, freon, checked relay switch, fuse, door blend alol fine still hot air, was told maybe a block in V shape hose is it temp control value Help
Only way to tell if A/C Evaporator Core Orifice tube is plugged is by looking at A/C gauge readings , An if it is plugged you more then likely need a new compressor , they become plugged with metal particles from worn out compressor. Your best bet would be to take your vehicle to a qualified repair shop .
Jun 27, 2016 | 1998 Lincoln Navigator
Hot air from drivers side cool air from passenger side
Driver's side blows hot air; passenger side cold air - Hyundai ...
www.hyundai-forums.com/.../294097-drivers-side-blows-hot-air%3B-pa...
Jul 29, 2014 - 3 posts - ‎3 authors I soon noticed that the driver's side blows warm air and the passenger side blowscold air as it should. No amount of adjusting the temp control ...
Hot air on driver side vents - Cold on passenger side - Page 3 ...
www.odyclub.com/.../46646-hot-air-driver-side-vents-cold-passenger-si...
May 9, 2012 - 16 posts - ‎10 authors I have a 2009 EXL Odyssey that just is doing the same thing (warm air on drivers side, cold on passenger). I checked freon levels and ...
Oct 15, 2015 | 2009 Hyundai Sonata
How do I find the Fuse Box on a 2008 Chrysler Sebring?
I doubt the issue is a fuse. If the blower is blowing, then the issue is hot air. You ably need to have your ZC re-charged Freon but first you need it leak checked. Both these require special equipment. Go to a place that does only auto AC. They will know what they're doing.
Aug 16, 2014 | 2008 Chrysler Sebring
My air conditioner blows warm air when stopped and idleing
Possible problems.
Air conditioner blows warm air?
Possible solution, system may need to be recharged.
You also wrote, temp light come on, gauge reads hot.
First check coolant level, always check this first.
Next, check your radiator hoses.
Next, have your thermostat checked, or change it. Their rather inexpensive.
Good luck.
Jun 20, 2012 | Air Conditioning and Heat for Pontiac...
Air Conditioner Blows hot air
Are you sure the relay isn't getting weak? Try swapping with another.
Dec 27, 2017 | 2007 Honda Odyssey
If your a/c is blowing hot air what should you do
Have the unit tested for proper refrigerant level and have the unit checked for any mechanical issue that would prevent the compressor from turning on
Jul 01, 2011 | Whirlwind FH-778 Air Conditioner
Air conditioner wont work
You need to check your freon level. Go to your auto parts store and pick up a can of freon with a gauge and follow the directions on the can.
Jun 07, 2010 | 1995 Nissan Maxima
Dometic Air conditioner model 57915-531 blows hot air
Have freon and compressor checked out, could also be bad capacitor
Aug 11, 2009 | Heating & Cooling
Air Conditioner blowing hot air
if your a/c is blowing hot air your system needs to be discharged and recharged with redtek a/c at your local canadian tire store.
Jul 23, 2009 | 2001 Daewoo Nubira
Air conditioner blows hot air, checked coolant and it is full
There are a few different possibilities for a vehicle doing this. A low refridgerant level can, or a temp control on the dash is not operating properly.
May 10, 2009 | 1998 Dodge Durango
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
